Analyzers
compiler compatibility
newport_j
i just installed an eval copy oof intel Parallel Advisor and I have just one question
Does it also work with gnu gcc compiler or just the Intel icc compiler?
Can it work with other compilers created by other software companies?
Any help appreciated. Thanks in advance.
Newport_j
Ravi_V_Intel
Hello Newport_j, Please download and install the recently launched Intel(R) Advisor XE 2013 component from the following link: http://software.intel.com/en-us/intel-software-evaluation-center Intel(R) Advisor XE 2013 is supported on both Windows and Linux. You can use either ICC or GCC or similar compilers. Please let me know if I can help further. Thank you. Intel Developer Support
Ravi_V_Intel
Hello Newport_j, I fixed the link - please double check now. Sorry for the inconvenience. Intel Developer Support
