Analyzers
5285 Discussions
details of "VTUNEDEMO.exe" application required...
k_g_v_s_prasad
VTune installation directory contains a "ExamplesVTuneDemo" sub directory which contain VTuneDemo application. I want to analyze this application with VTune. To do so I need details of that application. Can any body tell me where can I get those details..?
Prasad.
Daniel_B_Intel2
Prasad, ExamplesVTuneDemo dir includes also source files. Real "open source"! :-)
Please tell us, what additional details do you need?
k_g_v_s_prasad
Hello dbricker,
I want to know
-what does this VTuneDemo application do
-what are the performance bottlenecks it have
-any demo application might be having some demonistration objectives or goals. So I want to know what are the demonistration objectives/goals on which the VTuneDemo has been prepared...?
Prasad.
Intel_C_Intel
VTuneDemo application demonstrates VTune ability to find bottleneck using all available in VTune profiling methods.
The application contains 4 routines:
test_if - simple matrix operations that use global variable
test_if1 - the same as test_if, but use of local variable instead of global
test_memset - demonstrates, that manually written memset has performance problems, so it better to use memset from "C" runtime library
divd_rout - floating point division - bottleneck of the application
Those routines are run hundreds of times with independent time measurement. Timing results are displayed in the output window.
k_g_v_s_prasad
Hello kdmitry,
Thanks a lot for the information. I will try VTuneDemo sample.
Prasad.
