Analyzers
5341 Discussions
find integer vectorised ops
BenKo
It is fairly easy to find the percentage of vectorised floating point operations in an uninstrumented code (no debug symbols) including vector length (AVX or not). How to find if a code is vectorising integer operations? Preferably using HW counters.
More generally, what to look for in a code which is computationally intensive but has relatively little FP ops? Are there suitable templates for initial analysis?
Dmitry_P_Intel1
We don't have HW events that can calculate integer vectorized operations as we do for floating point operations.
We recommend to use Intel Advisor that shows very comprehensive information on both integer and floating point vectorization efficiency.
On this:
"More generally, what to look for in a code which is computationally intensive but has relatively little FP ops? Are there suitable templates for initial analysis?"
You can start with Microarchitecture Exploration Analysis type that will give you a pretty complete picture where you lose you performance in terms of different kind of stalls in instruction execution pipeline.
Thanks & Regards, Dmitry
