Hi guys,
I try to write and read to/from a intel_onChip Memory 2 RAM.
But it only sets the first or the last byte in the RAM to 0x00 depending on how high I set the ram_addr_reg.
I am using a Arria10 SOC Development Kit.
The initial file is transferred well with all data on the right spot.
And I can read and write the RAM from the C-Program on the Linux HPS.
But i then try to write something from the FPGA only the first Byte changes to 0x00.
This I can overwrite by the C-Programm again.
I can do this procedure as often as I want.
Do you see any mistake I've made in my code or the setup?
Please see code and pic attached.
Thanx,
Linus
