Analyzers
5307 Discussions
oneMKL getri offload to GPU
TestDR
I ran "getri.cpp" (oneAPI base toolkit examples @ /opt/intel/oneapi/mkl/2023.0.0/examples/examples_dpcpp.tgz.) through the Intel Advisor to compare  CPU to GPU offload analysis. It seems my old Xeon processor can do it as fast as a data center GPU Ponte Vecchio XT 512 XVE. Any idea?
Selected accelerator to analyze: Intel(R) Ponte Vecchio XT 512 XVE.
Baseline Host: Intel(R) Xeon(R) W-3225 CPU @ 3.70GHz.
Measured CPU Time: 4.520s Accelerated CPU+GPU Time: 4.520s
Speedup for Accelerated Code: 1.0x Number of Offloads: 0 Fraction of Accelerated Code: 0%
Compile and link settings
icpx -fsycl -fsycl-device-code-split=per_kernel -DMKL_ILP64 -I$MKLROOT/include -L$MKLROOT/lib/intel64 -DSYCL_DEVICES_cpu -lmkl_sycl -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lsycl -lOpenCL -lpthread -lm -ldl -O2 -g getri.cpp -o getri
Advisor CLIs
advisor --collect=survey --auto-finalize --static-instruction-mix --project-dir=./getri_run512 -- ./getri
advisor --collect=tripcounts --flop --stacks --auto-finalize --cache-simulation=single --data-transfer=light --target-device=pvc_xt_512xve --project-dir=./getri_run512 -- ./getri
advisor --collect=projection --no-assume-dependencies --config=pvc_xt_512xve --project-dir=./getri_run512 -- ./getri
Ruslan_M_Intel
That's right - Offload Modeling shows the same performance on PVC for this sample. Do you have PVC results as well? Could you please share them?
Ruslan Murtazin
TestDR
Hi Ruslan,
Do you mean the results on actual PVC GPU or any other PVC results generated by the intel advisor? Can you please be specific?
Rajitha
Ruslan_M_Intel
Hi Rajitha,
Yes, exactly! I meant Advisor GPU profiling result for the same app (but gathered on real PVC) to compare against Offload Modeling result.
Ruslan
RemyaP_Intel
We haven't received any response from your end. Is your issue resolved?
Remya Premdas
RemyaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
