Dima,
This seems to be a rather uncommon error that appears to have
various causes. I will take this forum thread
private so that I can gather serial number and other pertinent information to
troubleshoot the issue with you.
Thank you for pointing out the re-resolve description in the
on-line documentation. I will get this
fixed. The description for Re-resolve
and Open should read similar to Finalize the selected result again.
You may use this option after changing the search directories settings to
enable updating the symbol information.
- Rob
I have the following issue after running any vTune Amplifier analysis for a hello world application:
"Error 0x4000001f (No valid license) -- Your license file is unavailable for undetermined reasons. The error code is `-158'."
Environment:
- host system: Gentoo x86_64
- non-commercial license
- dev-lang/vtune-13.1.12.305106
Thank you.
Hi Nikita:
When installed, did you supply the serial number or a license file?
What is the output of the command 'echo $INTEL_LICENSE_FILE'? It should specify the directory that contains the license file(s), typically, /opt/intel/licenses. Are you sourcing the amplxe-vars.sh file?
MrAnderson (Intel) wrote:
Hi Nikita:
Hi MrAnderson,
When I requested the SW I received an email with "Your product serial number is: NVKT-MNGZSLTT".
My distribution asked me to provide a license file at /opt/intel/composerxe-2013.12.305106/licenses/*.lic before installation. What I did is I created license.lic file with "NVKT-MNGZSLTT" string inside. After that installation proceeded successfully. But I encounter the issue above when trying to analyze any profiling results.
Again, I do not have any license file from Intel. Only the serial number, which was sufficient for the installation, but not for usage.
Hi MrAnderson,
When I requested the SW, I received an email with "Your product serial number is: NVKT-MNGZSLTT".
I installed vTune Amplifier using my distribution package manager. It asked me for /opt/intel/composerxe-2013.12.305106/licenses/*.lic file before the installation. What I did is I put "NVKT-MNGZSLTT" string into license.lic file. After that installation proceeded successfully. Now I am able to run both GUI and CLI. But any attempt to analyze any profiling data leads to the error described above.
amplxe-vars.sh script does not export INTEL_LICENSE_FILE variable for me. The output is:
$ . /opt/intel/composerxe-2013.12.305106/amplxe-vars.sh
Copyright (C) 2009-2013 Intel Corporation. All rights reserved.
Intel(R) VTune(TM) Amplifier XE 2013 (build 305106)
