Analyzers
5340 Discussions
problems profiling large graphic-intensive windows application
trond_ystanes
When we try to profile a graphical-intensive windows application using Vtune for Windows, we have trouble. After we start vtune, the graphics in the application turn white and vtune crashes.
What we have installed atm is tprofile3.1_006_win and vtune9.0_005_win
We are wondering if anyone knows of problems in these versions with profiling large, intensive windows applications (e.g. a video game).
Thanks...
TimP
Large applications may work better with thread profiling when linked with the profiling library, run outside VTune, and the profile data imported into VTune.
jimdempseyatthecove
The graphics in my applicaion is not video game graphics but it is done using the Array Visualizer (AV). AV runs as a seperate app with shared memory (probably memory mapped file or pipe). How it is shared may not be important. When this app is running with an AV viewer running displaying 3D charts of a simulation, AV unfortunately has a minor memory leak. The reason this is significant to your problem is when the page file gets gobbled up then the graphics start flaking out. Things go blank or don't work.
Therefore, I suggest you examine how much of your page file is being consumed. If you are bumping the limit then consider enlarging the page file.
If all else fails, can you experiment with a profiler other than VTune?
Jim Dempsey
