Analyzers
5287 Discussions
profiling an opencl applications using vtune
RamyaSri01
I am using Intel VTune to profile an application ( a sample matrix program ) on windows 11. I got an error while profiling hotspots . The error is shown in screenshot attached herewith.
And also anyone help me to execute OpenCL benchmarks on intel integrated UHD 620 graphics and profile them to get timeseries data of low level counters like memory bandwidth, IPC, cache statistics?
Thanks and regards
Ramya Sri
ThasneemV_Intel
Thanks for getting back to us. We can observe from the provided screenshot that you are not using the official matrix sample. Can you kindly try running the analysis using the official matrix sample located at "C:\Program Files (x86)\Intel\oneAPI\vtune\latest\samples\en\C++\matrix\matrix.exe" and check if the issue still persists?
Thasneem Vazim
ThasneemV_Intel
Regarding your first issue related to Intel VTune, please provide us with the following information:
1) VTune version.
2) Exact steps and the commands used.
3) Are you running VTune as an administrator? If not, kindly try running VTune as an administrator and perform the analysis.
4) Could you kindly provide a screenshot of the Analysis configuration page, similar to the one attached for your reference?
Since the second issue is a duplicate thread of https://community.intel.com/t5/Graphics/profiling-opencl-benchmarks/m-p/1522499, we will continue addressing the issue there.
Thasneem Vazim
RamyaSri01
yes, I had run Vtune as an administrator only.  configuration screenshot attached here.
ThasneemV_Intel
Good day to you!
To assist you better, could you kindly share the following details:
1) VTune version.
3) Could you kindly provide a screenshot of the Analysis configuration page, similar to the one attached for your reference?
Thasneem Vazim
RamyaSri01
analysis configuration tab screenshot is attached here.
Ramya
ThasneemV_Intel
Thasneem Vazim
ThasneemV_Intel
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
RamyaSri01
Yes it is resolved for now thank you. I will try for local programs also. If it doesn't work , I will post query.
Thank you
Ramya
ThasneemV_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
