Analyzers
remote agent error
huckym
I am trying to run a remote sampling collection activity on linux. Started vtserver on the target machine of interest and then setup the activity in GUI running on a linux host and set the remote system to the target machine appropriately.
When I start the run, I can see the messages on the target machine about connection acceptance and run started but it errors out with the following message
[ERROR] sampling collector reported error (42): Bad event modifier
Can someone help? My sampling run is EBS with default events of "Clockticks" and "Instructions Retired"
Host: Intel 5160
Remote system: Intel 5460
huckym
The following is the error log from the remote agent on which I am trying to collect sampling data
000 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: pValue=(0)
000 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: session_id=(hakim@eval5-1749)
000 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: callback_port=(37898)
000 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: user_id=(hakim)
000 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: clientVersion=(vt 9.0, protocol version 0.0), EXTRA_VERSION=(vt 9.0, protocol version 0.0)
000 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: retval=()
000 09/02/2008 11:28:08 17454 [DEBUG] **** samplingCollector: pMethod=DoStart, argument=0, clientusername=hakim, clienthostname=intel0332, clientipname=10.30.80.142, retval=
001 09/02/2008 11:28:08 17454 received request from hakim@intel0332
001 09/02/2008 11:28:08 17454 [DEBUG] samplingCollector.DoStart: calling start
001 09/02/2008 11:28:08 17454 sampling run started ...
001 09/02/2008 11:28:08 17454 [ERROR] sampling collector reported error (42): Bad event modifier
001 09/02/2008 11:28:08 17454 [DEBUG] samplingCollector.DoStart: child pid=17454, parent pid=17196
001 09/02/2008 11:28:08 17454 [DEBUG] processSOAPPOSTData: unable to perform sampling
001 09/02/2008 11:28:08 17454 [DEBUG] createSOAPResponseMessage: sent message ...
HTTP/1.1 200 OK
Connection: Keep-Alive
Content-Type: text/xml
Content-Length: 772
S_NOT_OK
Remote agent on eval5 (127.0.0.1) port 50000 reports:
[ERROR] Attempt to perform sampling failed.
001 09/02/2008 11:28:08 17454 [DEBUG] createAndSendSoapResponseMessage: message sent to client
001 09/02/2008 11:28:08 17454 [DEBUG] main: server is waiting on select ...
001 09/02/2008 11:28:13 17454 [DEBUG] processing fd=4
001 09/02/2008 11:28:13 17454 [DEBUG] main: calling ...
001 09/02/2008 11:28:13 17454 [DEBUG] Calling receiveData...
001 09/02/2008 11:28:13 17454 [DEBUG] receiveData: received message from socket 4
001 09/02/2008 11:28:13 17454 [ DEBUG] receiveData done...
001 09/02/2008 11:28:13 17454 [DEBUG] main: disconnecting client on file descriptor 4
001 09/02/2008 11:28:13 17454 [DEBUG] main: normal VTServer shutdown ...
001 09/02/2008 11:28:13 17454 [DEBUG] shutdownServer: ShutdownStart message sent to vtlistenerd, res=20
001 09/02/2008 11:28:13 17454 [DEBUG] shutdownSamplingCollector: entering
001 09/02/2008 11:28:13 17454 [DEBUG] shutdownSamplingCollector: stopping the sampling driver
001 09/02/2008 11:28:13 17454 please wait while the sampling collector finishes ...
001 09/02/2008 11:28:15 17454 [DEBUG] shutdownSamplingCollector: closing sampling driver
001 09/02/2008 11:28:15 17454 [DEBUG] closeLibrary: attempting to close
001 09/02/2008 11:28:15 17454 [DEBUG] closeLibrary: closure successful
001 09/02/2008 11:28:15 17454 [DEBUG] shutdownSamplingCollector: exiting
001 09/02/2008 11:28:15 17454 [DEBUG] main: closed sampling
001 09/02/2008 11:28:15 17454 [DEBUG] main: closed client socket ...
001 09/02/2008 11:28:15 17454 [DEBUG] main: closed domain socket ...
001 09/02/2008 11:28:15 17454 [DEBUG] main: freed read buffer ... exit complete
001 09/02/2008 11:28:15 17454 [DEBUG] exiting server ... goodbye!
vtlistenerd: 09/02/08 11:28:15 [DEBUG] child 17454 terminated.
vtlistenerd: 09/02/08 11:28:15 [DEBUG] associated session entry is removed, 0 remains.
