Analyzers
5285 Discussions
[solved] Changing APS output directory
Gabriel_S_1
i've been using MPS for a while and switched to APS recently with the  2018 beta.
I used to use the MPS_FILE_POSTFIX variable to change the output directory as currently the output is aps_result_YEARMONTHDAY , not very praticle for multiple tests on the same day ..
Is there a way to change the directory name ?
thank you
Gabriel_S_1
Nevermind, just checked the aps -h .
I belevie the default directory should still be unique but indeed using the -r=directory option at the collection stage it is simple to  do as i wanted.
