Analyzers
5320 Discussions
source/assembly code for the selected object is not available
hui_yuan
I encountered a problem when using Intel vtune profiler.
As shown in the figure below, I performed hot spot analysis on the program, but no results were displayed in the end. The error prompt is as shown in Figure 2.
Has anyone encountered a similar problem?
yuzhang3_intel
Please attach the screenshot of the function you selected in the 'Bottom-up' tab.
hui_yuan
no data to show
yuzhang3_intel
Could you share the VTune data with me? Let me check. The folder name should be r000hs, and can you provide the VTune version and platform information as well?
hui_yuan
data file attached.
The version is VTune profiler 2024.2.1.
The platform is windows 11
yuzhang3_intel
Please specify a new working path and remove the special characters, like ® and ™. Try again.
D:\projects\PG_MHT\CAE-master\Code\main\Intel® VTune™ Profiler Results\PGThermoStr
hui_yuan
problem solved. Thank you very much.
非常感谢!
