Analyzers
text editor error
newport_j
When I try to open the external text editor for this file. It says :
Cannot open the external text editor for this file. Suggestion:
make sure the text editor is set in the EDITOR or VISUAL environment
variable and supports a filename as an argument.
I must have failed to do something when I was setting up this program
on the nqueens problem. Please tell me how to fix this problem.
 Any help appreciated Thanks in advance.
Newport_j
Ravi_V_Intel
Hello newport_j, Depending on the OS you are on, you need to point the EDITOR or VISUAL environment variable to an appropriate editor (executable). Please set the variable prior to launching the Intel(R) Advisor XE 2013 GUI. Here are instructions about how to do it on Windows: Windows* instructions and how to do it on Linux: Linux* instructions Please let me know if I can help further. Thank you. Intel Developer Support
newport_j
The link that you sent me in the previous email or forum reply does not work. This has happened in all of the links that you have sent me. Please just send the document as an attachment. Thanks in advance. Newport_j .
Ravi_V_Intel
Hello Newport_j, I fixed the link - please double check now. Sorry for the inconvenience. Intel Developer Support
