Analyzers
5307 Discussions
vtuen problem:why 'input and output' and macc analyzes did not capture all processes
YitianZheng
If someone could provide assistance, I would be deeply grateful:
Background: I have written a script named fillrandom_no_group.sh which connects 16 rocksdb benchmark instances, ./db_bench, with an '&' between them. By calling fillrandom_no_group.sh, 16 db_bench processes are sequentially launched, which will subsequently run concurrently.
The server configuration is as follows: Ubuntu 22.04 CPU: INTEL(R) XEON(R) GOLD 6530 (Logical CPU count: 128).
My problem:
When running fillrandom_no_group.sh, I observed in htop that all 16 processes were running, each containing multiple threads. When I ran 'hotspots' analysis, the output from VTune largely matched what I observed in htop (see Figure 1).
However, when I ran 'input and output' analysis, I noticed significant discrepancies in CPU utilization compared to 'hotspots' analysis (see Figure 2). This was reflected in CPU time, total thread count, and utilization.
Moreover, in the bottom-up dropdown menu, only 5 db_bench processes were visible (see Figure 3). It seems that the 'input and output' analysis did not capture all processes invoked by the analyzed script, resulting in inaccuracies in CPU-related data. What could be the reason for this? How can I adjust for correct testing?
yuzhang3_intel
Could you attach IO VTune data and Hotspots VTune data as well?
YitianZheng
Sorry, are you referring to the file ending in. vtune, the entire folder, or something else?
yuzhang3_intel
After profiling, you can get some VTune data folders, like r00hs, r01io, etc. The folders contain some information.
