Analyzers
5339 Discussions
vtune opening wrong source code file
Sylvain
I use vtune 2021 to analyze a c++ program I wrote compiled with gcc under linux. Problem is when editing the main function, the source code file opened is an header file and not the ccp file.
I added the source file path but does not help.
I checked that I compiled with -g.
I tried adding all those flags, but did not help :
-shared-libgcc
-gdwarf-3
-fno-eliminate-unused-debug-symbols
-femit-class-debug-always
-fno-merge-debug-strings
-fvar-tracking
-pipe
-fvar-tracking-assignments
-gcolumn-info
-gstatement-frontiers
-gvariable-location-views
-fno-eliminate-unused-debug-types
-fno-omit-frame-pointer
Any idea what I did wrong ? Or is it a bug ?
For example on command line I get
vtune -report hotspots -column=source,instructions,cpi -r /home/sylvain/intel/vtune/projects/Test\ SIMD/r007hs -source-search-dir=/home/sylvain/Recherche/Development/optim_robot_linux/test_vector_matrix_simd/ -search-dir=/home/sylvain/Recherche/Development/optim_robot_linux/test_vector_matrix_simd/bin/Release/ -search-dir=/home/sylvain/Recherche/Development/optim_robot_linux/test_vector_matrix_simd/obj/Release/
vtune: Using result path `/home/sylvain/intel/vtune/projects/Test SIMD/r007hs'
vtune: Executing actions 75 % Generating a report Column filter is ON.
Function Instructions Retired Microarchitecture Usage:CPI Rate Source File
main 29,952,000,000 0.433 DenseStorage.h
_mm256_fmadd_pd 894,400,000 0.477 fmaintrin.h
_mm256_fmadd_pd 405,600,000 0.782 fmaintrin.h
_mm256_load_pd 270,400,000 1.240 avxintrin.h
Eigen::internal::scalar_sum_op<double, double>::operator() 444,600,000 0.462 BinaryFunctors.h
_mm_add_sd 361,400,000 0.367 emmintrin.h
_mm256_add_pd 195,000,000 0.467 avxintrin.h
boost::numeric::ublas::vector<double, boost::numeric::ublas::unbounded_array<double, std::allocator<double>>>::iterator::operator= 0 vector.hpp
UME::SIMD::SIMDVec_f<double, (unsigned int)4>::assign 423,800,000 0.239 UMESimdVecFloat64_4.h
_mm256_add_pd 241,800,000 0.344 avxintrin.h
boost::numeric::ublas::vector<double, boost::numeric::ublas::unbounded_array<double, std::allocator<double>>>::iterator::operator++ 0 vector.hpp
boost::numeric::ublas::vector<double, boost::numeric::ublas::unbounded_array<double, std::allocator<double>>>::iterator::operator= 5,200,000 3.500 vector.hpp
boost::numeric::ublas::vector<double, boost::numeric::ublas::unbounded_array<double, std::allocator<double>>>::iterator::operator+= 15,600,000 1.000 vector.hpp
prepare_exit_to_usermode 0 [Unknown]
__do_softirq 0 0.000 [Unknown]
boost::numeric::ublas::vector<double, boost::numeric::ublas::unbounded_array<double, std::allocator<double>>>::iterator::operator+= 2,600,000 1.000 vector.hpp
Denis_M_Intel
It could be caused by 2 possible reasons:
 1. quality of the debugging information generated by compiler (What compiler version is used?);
or
 2. improper handling of the debug info in VTune in some cases;
To understand what is wrong exactly we need a reproducer: this binary file + VTune result directory.
You can also try to verify correctness of the debug information in your executable file with Linux tools like addr2line.
Sylvain
Thank you for your quick answer
Find attached like proposed the binary and the vtune result directory. I looked at addr2line, but do not know which address I should check.
Sylvain
Denis_M_Intel
Thank you.
I've downloaded the attachments and reproduced this issue. I'll open an internal bug request on VTune.
Denis.
AthiraM_Intel
Sorry for the delay.
The issue will be fixed in future release.
AthiraM_Intel
The issue is resolved with the latest release.
VTune 2021.9.0 is available for download as a standalone tool at https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html#vtune or as part of oneAPI Base Toolkit 2021.4 at  https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html
Could you please try with the latest release and let us know whether your issue is resolved?
AthiraM_Intel
Is your issue resolved? Could you please give us an update?
AthiraM_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Sylvain
Sorry for the late answer, I was busy on other work.
The new version indeed solves the problem.
Thanks, best regards,
Sylvain
