Analyzers
5273 Discussions
vtune profiler 2022 driver build errors
jparke161
Trying to build sepdk driver on openSUSE Tumbleweed, Linux 5.18.6.
Getting the following errors:
Building sep driver ...
/tmp/vtune_profiler_2022.2.0.623516/sepdk/src/linuxos.c: In function ‘LINUXOS_Install_Hooks
/tmp/vtune_profiler_2022.2.0.623516/sepdk/src/linuxos.c:95:18: error: ‘PROFILE_MUNMAPundeclared (first use in this function)
95 | #define MY_UNMAP PROFILE_MUNMAP
/tmp/vtune_profiler_2022.2.0.623516/sepdk/src/linuxos.c:1301:34: note: in expansion of macro ‘MY_UNMAP’
1301 | err = profile_event_register(MY_UNMAP, &linuxos_exec_unmap_nb);
/tmp/vtune_profiler_2022.2.0.623516/sepdk/src/linuxos.c:95:18: note: each undeclared identifier is reported only once for each function it appears in
/tmp/vtune_profiler_2022.2.0.623516/sepdk/src/linuxos.c:94:18: error: ‘PROFILE_TASK_EXITundeclared (first use in this function)
94 | #define MY_TASK PROFILE_TASK_EXIT
make[2]: *** [/usr/src/linux-5.18.6-1/scripts/Makefile.build:289: /tmp/vtune_profiler_2022.2.0.623516/sepdk/src/linuxos.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [../../../linux-5.18.6-1/Makefile:1852: /tmp/vtune_profiler_2022.2.0.623516/sepdk/src] Error 2
make: *** [Makefile:215: default] Error 2
Failed to build the drivers
Is there any fix for this?
John
JaideepK_Intel
You are getting this issue because you are trying to run in an unsupported OS. Can you please try to run it on a supported operating system?
To view the list of operating systems, please follow the below link.
Link: Intel® VTune™ Profiler System Requirements
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Jaideep
JaideepK_Intel
Jaideep
jparke161
Am going to move to Red Hat 8.
John
JaideepK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel. Have a great day ahead.
Jaideep
