Analyzers
5342 Discussions
vtune remote analysis error
silvio_stanzani
I setup Vtune on windows 8 to run the experiment using ssh on a linux server.
When i try to create an analysis the following message error appears:
"remote analysis error "detected Vtune Amplifier build #403110 on target system is incompatible with the build #410668 on the host". Package update on target is required.
Amplifier cannot detect remote machine configuration
What shoud i do to solve this incompatibility?
Silvio
David_A_Intel1
Hi Silvio:
As the message implies, you need the same or newer release on the remote system.  If the remote system is newer, the client won't be able to parse the results data scheme.  There is backward compatibility, but not forward.
