Analyzers
5281 Discussions
vtune self-check fails on GPU Compute/Media Hotspots
Chuyuezh
I'm running vtune on
OS: ubuntu22.04
vtune: 2023.1.0
CPU: Intel i7-12700H
GPU: Intel iris Xe Gen12
When running vtune-self-checker.sh:
root@ubuntu2204:/opt/intel/oneapi/vtune/latest/bin64# ./vtune-self-checker.sh
Intel(R) VTune(TM) Profiler Self Check Utility
Copyright (C) 2009 Intel Corporation. All rights reserved.
Build Number: 625246
HW event-based analysis (counting mode) (Intel driver)
Example of analysis types: Performance Snapshot
    Collection: Ok
    Finalization: Ok...
    Report: Ok
Instrumentation based analysis check
Example of analysis types: Hotspots and Threading with user-mode sampling
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis check (Intel driver)
Example of analysis types: Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
    Collection: Ok
    Finalization: Ok...
vtune: Warning: Cannot locate debugging information for the Linux kernel. Source-level analysis will not be possible. Function-level analysis will be limited to kernel symbol tables. See the Enabling Linux Kernel Analysis topic in the product online help for instructions.
    Report: Ok
Example of analysis types: Microarchitecture Exploration
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with uncore events (Intel driver)
Example of analysis types: Memory Access
    Collection: Ok
    Finalization: Ok...
vtune: Warning: The result contains a lot of raw data. Finalization may take a long time to complete.
    Report: Ok
HW event-based analysis with stacks (Intel driver)
Example of analysis types: Hotspots with HW event-based sampling and call stacks
    Collection: Ok
    Finalization: Ok...
    Report: Ok
HW event-based analysis with context switches (Intel driver)
Example of analysis types: Threading with HW event-based sampling
    Collection: Ok
    Finalization: Ok...
    Report: Ok
Checking DPC++ application as prerequisite for GPU analyses: Fail
Unable to run DPC++ application on GPU connected to this system. If you are using an Intel GPU and want to verify profiling support for DPC++ applications, check these requirements:
* Install Intel(R) GPU driver.
* Install Intel(R) Level Zero GPU runtime.
* Install Intel(R) oneAPI DPC++ Runtime and set the environment.
The system is ready to be used for performance analysis with Intel VTune Profiler.
Review warnings in the output above to find product limitations, if any.
The system is ready for the following analyses:
* Performance Snapshot
* Hotspots and Threading with user-mode sampling
* Hotspots with HW event-based sampling, HPC Performance Characterization, etc.
* Microarchitecture Exploration
* Memory Access
* Hotspots with HW event-based sampling and call stacks
* Threading with HW event-based sampling
The following analyses have failed on the system:
* GPU Compute/Media Hotspots (characterization mode)
* GPU Compute/Media Hotspots (source analysis mode)
Log location: /tmp/vtune-tmp-root/self-checker-2023.06.08_16.19.44/log.txt
Drivers are already loaded properly:
root@ubuntu2204:/opt/intel/oneapi/vtune/latest/sepdk/src# ./insmod-sep -q
pax driver is loaded and owned by group "vtune" with file permissions "660".
socperf3 driver is loaded and owned by group "vtune" with file permissions "660".
sep5 driver is loaded and owned by group "vtune" with file permissions "660".
socwatch2_15 driver is loaded and owned by group "vtune" with file permissions "660".
vtsspp driver is loaded and owned by group "vtune" with file permissions "660".
When running vtune-gui:
root@ubuntu2204:/opt/intel/oneapi/vtune/latest/bin64# ./vtune-gui
[36953:0608/163730.647467:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
[36925:0608/163731.099072:ERROR:cert_verify_proc_builtin.cc(670)] CertVerifyProcBuiltin for 127.0.0.1 failed:
----- Certificate i=0 (CN=ubuntu2204) -----
ERROR: No matching issuer found
No error message on vtune-gui analysis configuration:
The analyzing process always stuck in finalizing result:
Could you please help me fix this issue? I know there are similar posts. But those solutions cannot solve my issue. Thanks in advance.
DiyaN_Intel
Thank you for posting in Intel communities.
We were able to reproduce the issue from our end.
In order to access GPU we need to upgrade the kernel version.
In this link ,  please give all the commands one by one to install all the necessary packages and reboot the system.
After upgrading you can check that the kernel version is updated to 5.19.0-41-generic
The next step is to build and install Intel(R) Metrics Discovery Application Programming Interface.
Please follow all the steps mentioned in this link
Then when you can run the self-checker script file to find out that there is no failed analysis as everything is installed properly in the system and then you will be able to open the vtune-gui and do the necessary analysis.
If you face any issues, please get back to us.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues. Thank you!
Diya
Chuyuezh
Hi Diya,
Thanks a lot for your solution. I had trouble in upgrading the kernel version, and I'm reinstalling ubuntu. I will get back to you later.
Best,
Chuyue
Chuyuezh
Hi Diya,
I have updated the kernel to 5.19.0-41-generic.
But GPU Compute/Media Hotspots still cannot work.
Other than that, ./insmod-sep -q shows that drivers are not loaded after reboot, which might be the problem. Before I install metrics-discovery and reboot, drivers are loaded. Attached please find the log.
DiyaN_Intel
Good day to you.
We can see from the logs that you are using Vtune 2023.0.0, can you update it to the latest one (2023.1.0).
We can also see from the logs that the drivers are not installed properly, could you please load the drivers and run the self-checker logs once again?
Diya
DiyaN_Intel
Good day to you.
We have not heard back from you.
Is your issue resolved with the above solution?
Thanks and Regards,
Diya
Chuyuezh
Hi Diya,
I was out of office last week. Sorry for the late reply.
Thanks for your suggestion. I loaded the drivers:
root@ubuntu2204:/opt/intel/oneapi/vtune/2023.0.0/sepdk/src# ./insmod-sep -q
socwatch driver is loaded and owned by group "vtune" with file permissions "660".
 But  GPU Compute/Media Hotspots is still not working. Please check log0626.txt attached.
I have used the VTune 2023.1.0 version before, and the results were the same as 2023.0.0. So I downgraded afterwards.
Chuyue
DiyaN_Intel
Can you please try one more thing and show us the result of what you are getting?
Please give the below command and let us know what output you are getting and share the screenshot. This will help us to debug further.
sycl-ls
Thanks and Regards,
Diya
Chuyuezh
I run sycl-ls and it shows no GPU device detected. How to get it fixed?
Thanks a lot.
Chuyue
DiyaN_Intel
Good day to you.
Based on our discussion about creating a priority ticket if needed, I am going ahead and closing this case for now.
Please feel free to contact us further if you need any assistance from our side.
Thanks & Regards,
Diya
Xuejun1
Hi Diya,
             I got the same error in windows, with vtune 2024.1.0. And I had also updated the gpu driver. Any suggestions?
Xuejun
yuzhang3_intel
Install GPU drivers and computation runtime by following the steps below. If all dependencies are installed, you can get GPU connection information from the output of $sycl-ls
https://dgpu-docs.intel.com/driver/installation.html
Xuejun1
This issue from Windows, not Linux. Any solution for Windows?
yuzhang3_intel
Install the GPU driver and runtime below, and run the self-check utility then.
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
Xuejun1
@yuzhang3_intel  Installed the driver, get the same error
* Memory Access
yuzhang3_intel
Please provide the Windows version, OS build, and CPU information.
Xuejun1
yuzhang3_intel
Run the binary below and post the output.
C:\Program Files (x86)\Intel\oneAPI\vtune\2024.1\bin64\self_check_apps
Xuejun1
C:\Program Files (x86)\Intel\oneAPI\vtune\2024.1\bin64\self_check_apps is a folder not a binary.
u mean self_check.py?
yuzhang3_intel
Is there a binary in the self_check_apps folder below? If yes, please run the binary and get the output.
C:\Program Files (x86)\Intel\oneAPI\vtune\latest\bin64\self_check_apps\matrix.dpcpp\matrix.dpcpp.exe
Xuejun1
