Analyzers
5269 Discussions
vtune top down microarchitecture metrics
zytsnlz
multiple runs the application many times to make sure the vtune collection time was long enough. The sum of Retiring,Front-End Bound,Bad Speculation,Back-End Bound of many functions in the collected results is over 100% a lot. Why?
AthiraM_Intel
We have observed the same issue and we are checking on this internally.
Meanwhile could you please share the below details:
  1. OS details
  2. VTune version
  3. Hardware details
zytsnlz
OS details
      Linux ICT-01 4.18.0-147.5.1.6.h605.eulerosv2r9.x86_64 #1 SMP Wed Nov 10 09:00:30 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
VTune version
       vtune_profiler_2022.3.0.624050
Hardware details
AthiraM_Intel
Thanks for sharing the details. We are working on this internally. We will get back to you with an update.
AthiraM_Intel
Thank you for your patience.
This can happen due to the nature of sampling methodology VTune take. In general, sampling methodology will not be able to provide 100% accurate data. Due to the complexities of implementation to cause underestimates or overestimates, use multiple runs option could help approximate more accurate data. In general, the statistical portions of pipeline categories classifications would be meaningful data to try categorizing the performance bottleneck problems.
Hope this clarifies your query.
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
