Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Intel FPGA AI Suite Inference Engine
RubenPadial
I'm using Intel FPGA AI 2023.2 on ubuntu 20.04 host computer and trying to infer a custom CNN in a Intel Arria 10 SoC FPGA.
I have followed Intel FPGA AI Suite SoC Design Example Guide and I'm able to copile the Intel FPGA AI suite IP and run the M2M and S2M examples.
I have also compiled the grpah for my custom NN and I'm trying to run it with the Inter FPGA AI suite IP but I have not clear how to do it. I'm trying to use the dla_benchmark app provided but for example, the input data of my NN (it is trained and graph was compiled in this way) must be float whereas the input data of the IP must be int8 if I'm not wrong.
Another problem I have is regarding the ground truth file. I have a ground truth file for each imput file because each groud truth is a 225 array.
Is there any additional information or guide to run custom model with Intel FPGA AI Suite?
Thank you in advance
RubenPadial
Hello @JohnT_Intel ,
What changes are needed?
JohnT_Intel
May I know if you regenerate the model using the TensorFlow 2 models optimization?
https://docs.openvino.ai/2023.2/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
RubenPadial
Hello @JohnT_Intel,
According to the link you sent only  mo --saved_model_dir <SAVED_MODEL_DIRECTORY> for saved model files. That exacly what I'm doing.
RubenPadial
JohnT_Intel
I observed that the file provided does not support certain layer on FPGA side. This will cause the you to pass between FPGA and CPU.
I have check on the file you provided, it looks there is multiple layer that is not supported by FPGA.
Layer (Name: StatefulPartitionedCall/model/dense_1/BiasAdd, Type: Eltwise) is not supported: FPGA plugin: all parent nodes are not supported by FPGA.
Layer (Name: Constant_2560, Type: Constant) is not supported:
Layer (Name: StatefulPartitionedCall/model/dense_1/Tensordot, Type: Reshape) is not supported:
FPGA plugin: layer is not executed on FPGA because it does not have preceding layer on FPGA.
Layer (Name: StatefulPartitionedCall/model/dense_1/Tensordot/MatMul, Type: FullyConnected) is not supported:
FPGA plugin: this Fully Connected layer does not have preceding convolutional layer / sequence.
Layer (Name: StatefulPartitionedCall/model/re_lu_7/Relu, Type: Relu) is not supported:
Layer (Name: StatefulPartitionedCall/model/dense/BiasAdd, Type: Eltwise) is not supported:
FPGA plugin: 'Constant' nodes are not supported as input of nodes Eltwise
Layer (Name: Constant_2559, Type: Constant) is not supported:
RubenPadial
According to Intel FPGA AI Suite. IP Reference Manual section 2.3. some of that layers should be compatible like the ReLU layer. Could you confirm? In addition, the model is compiled for HETERO plugin (--fplugin option), if the layer cannot be implemented in FPGA, it should be implemented in the CPU. What solution do you suggest?
Plase note that someof that layers are not in the intioan TensorFlow model and they are included by the OpenVINO model optimizer (mo) application.
JohnT_Intel
You will need to check on A10_Performance.arch on what type of confiuguration setting you are using on the FPGA design.
JohnT_Intel
Can we consolidate all the AI Suite disucssion into single forum discussion?
RubenPadial
I prefer to manage the issues or questions in different threads as they seem to have different root causes.
RubenPadial
Hello @JohnT_Intel,
Is there any official documentation on the DLA runtime or inference engine for managing the DLA from the ARM side? I need to develop a custom application for running inference, but so far, I’ve only found the dla_benchmark (main.cpp) and streaming_inference_app.cpp example files. There should be some documentation covering the SDK.
From what I understand, the general inference workflow involves the following steps:
  1. Identify the hardware architecture
  2. Deploy the model
  3. Prepare the input data
  4. Send inference requests to the DLA
  5. Retrieve the output data
JohnT_Intel
Please create new forum to discuss on the DLA runtime or inference engine documentation
