Artificial Intelligence (AI)
875 Discussions
Intel OnLogic Edge AI Awards
CARYNFRITZ
Why Intel and OnLogic Are Celebrating the Leap from Pilot to Production
The OnLogic + Intel Edge AI Awards exist to honor a specific, hard-won milestone: the moment an edge AI project stops being a proof-of-concept and becomes a real, scaled deployment, and that milestone is exactly why our companies felt compelled to create a recognition program around it.
The Real Bottleneck Isn't Technology
Industry data makes clear why this matters so much right now. Analysts have catalogued more than 60 distinct failure points between proof-of-concept and production rollout, and the ones that actually kill deployments cluster around solution strategy and enterprise integration rather than raw technical capability. Intel has echoed this directly, noting that thousands of companies have run successful edge AI pilots, but only a fraction have successfully scaled them, and the gap comes down to decisions made (or not made) long before deployment ever began. That gap between "it worked in the lab" and "it works across 50 facilities" has earned its own grim nickname in the industry: pilot purgatory.
Awards as a Signal, Not Just a Trophy
Given how common it is for edge AI initiatives to stall, an award recognizing organizations that actually break through deserves real weight. At Automate 2026, the inaugural OnLogic Edge Ambassador Award went to Channa Samynathan of Exein specifically for work that moved "past digital hype to turn complex ideas into scalable realities," from co-building integrations to architecting live demonstrations that prove out advanced use cases on rugged hardware. That framing is deliberate. The award isn't celebrating a clever demo; it's celebrating the unglamorous, difficult engineering work of hardening a concept until it survives contact with the real world.
What Separates Scaled Deployments From Stuck Pilots
Industry conversations throughout 2026 have converged on a consistent list of what actually determines whether an edge AI project scales, and it maps directly onto what these awards are designed to recognize.
  • Architectural decisions made early: choosing custom software, off-the-shelf tooling, or configurable accelerators determines whether a solution can scale from one site to 50, not just whether it works in a single pilot
  • Field-ready hardware: intermittent connectivity, harsh physical environments, and zero on-site IT support are what turn promising pilots into perpetual proof-of-concepts, making purpose-built, rugged systems a prerequisite rather than a nice-to-have
  • Cross-functional collaboration: panelists at Automate 2026, including representatives from Dell, Wind River, and the EDGE AI FOUNDATION, emphasized that scaling intelligent systems takes clear business outcomes and strong collaboration across engineering, IT, and operations, not just working code
  • A practical path to manage systems at scale: the difference between a single successful pilot and an enterprise rollout is often the orchestration and management layer, not the AI model itself
Recognizing the People Who Do This Work
This is precisely why an awards program focused on individuals, not just products, matters. Solutions engineers and field partners are the ones translating architecture decisions and rugged hardware choices into functioning deployments day after day, and their contributions rarely get the visibility that a flashy product launch does. By putting a name and a face on that work, the OnLogic + Intel Edge AI Awards give the industry a concrete example of what "moving past pilot purgatory" actually looks like in practice, rather than leaving it as an abstract industry challenge.
Why This Recognition Matters Now
2026 has been widely flagged as a genuine inflection point for edge AI, with organizations across manufacturing, transportation, and retail under pressure to prove out real ROI rather than just experiment. In that environment, an awards program that specifically celebrates the transition from experimental pilot to mission-critical business asset sends an important signal to the broader market: scaling is the hard part, and it deserves to be treated as the achievement it is.
If your organization, or a partner you work with, has pushed an edge AI project past the pilot stage and into real-world scale, this is the recognition it deserves. Learn more about the program and submit an entry at onlogic.com/edge-ai-awards.
