Client
Interact with Intel® product support specialists on client concerns and recommendations
54 Discussions
Intel Core 13th and 14th Gen Desktop Instability Root Cause Update
Thomas_Hannaford
6 43 735K
Following extensive investigation of the Intel® Core™ 13th and 14th Gen desktop processor Vmin Shift Instability issue, Intel can now confirm the root cause diagnosis for the issue. This post will cover Intel’s understanding of the root cause, as well as additional mitigations and next steps for Intel® Core™ 13th and 14th Gen desktop users.
Vmin Shift Instability Root Cause
Intel® has localized the Vmin Shift Instability issue to a clock tree circuit within the IA core which is particularly vulnerable to reliability aging under elevated voltage and temperature. Intel has observed these conditions can lead to a duty cycle shift of the clocks and observed system instability.
Intel® has identified four (4) operating scenarios that can lead to Vmin shift in affected processors:
  1. Motherboard power delivery settings exceeding Intel power guidance.
    a.  Mitigation: Intel® Default Settings recommendations for Intel® Core™ 13th and 14th Gen desktop processors.
  2. eTVB Microcode algorithm which was allowing Intel® Core™ 13th and 14th Gen i9 desktop processors to operate at higher performance states even at high temperatures.
    a.  Mitigation: microcode 0x125 (June 2024) addresses eTVB algorithm issue.
  3. Microcode SVID algorithm requesting high voltages at a frequency and duration which can cause Vmin shift.
    a.  Mitigation: microcode 0x129 (August 2024) addresses high voltages requested by the processor.
  4. Microcode and BIOS code requesting elevated core voltages which can cause Vmin shift especially during periods of idle and/or light activity.
    a.  Mitigation: Intel® is releasing microcode 0x12B, which encompasses 0x125 and 0x129 microcode updates, and addresses elevated voltage requests by the processor during idle and/or light activity periods.
Regarding the 0x12B update, Intel® is working with its partners to roll out the relevant BIOS update to the public.
Intel’s internal testing comparing 0x12B microcode to 0x125 microcode – on Intel® Core™ i9-14900K with DDR5 5200MT/s memory1  - indicates performance impact is within run-to-run variation (ie. Cinebench* R23, Speedometer*, WebXPRT4*, Crossmark*). For gaming workloads on Intel® Core™ i9-14900K with DDR5 5600MT/s memory2, performance is also within run-to-run variation (ie. Shadow of the Tomb Raider*, Cyberpunk* 2077, Hitman 3: Dartmoor*, Total War: Warhammer III – Mirrors of Madness*). However, system performance is dependent on configuration and several other factors.
Intel® reaffirms that both Intel® Core™ 13th and 14th Gen mobile processors and future client product families – including the codename Lunar Lake and Arrow Lake families - are unaffected by the Vmin Shift Instability issue. We appreciate our customers’ patience throughout the investigation, as well as our partners’ support in the analysis and relevant mitigations.
Next Steps
For all Intel® Core™ 13th/14th Gen desktop processor users: the 0x12B microcode update must be loaded via BIOS update and has been distributed to system and motherboard manufacturers to incorporate into their BIOS. Intel is working with its partners to encourage timely validation and rollout of the BIOS update for systems currently in service.  This process may take several weeks.
Users can check their system/motherboard manufacturer’s website and/or the Intel® Product Compatibility Tool to see the latest BIOS versions for their Intel® Core™ 13th and/or 14th Gen-powered desktop systems: https://compatibleproducts.intel.com/.
  1. Processor: Intel® Core™ i9-14900K, Motherboard: Intel Raptor Lake Reference Board (M40919), Memory: 64GB DDR5 at  5200MT/s, Storage: ADATA* SU360, Graphics: Intel® UHD Graphics 770, Graphics Driver Version: 32.0.101.5768, Display Resolution: 1280x800, Operating System: Windows 11 Pro (version 26100.712).
  2. Processor: Intel® Core™ i9-14900K, Motherboard: Intel Raptor Lake Reference Board (RVP SR19), Memory: 32GB DDR5 at  5600MT/s, Storage: Samsung* 990 Pro 1TB, Graphics: MSI* RTX 4090 Suprim X, Graphics Driver Version: NVIDIA* v555.99, Resolution: 1920x1080, Operating System: Windows 11 (version 22631.4169)
43 Comments
Vlad11
@CommonRustyMullet You mentioned that you had an RMA on your i9-14900k, and that you still have issues with the replacement CPU. Can I ask when did you get the replacement? And what microcode have you ran it with immediately after replacing it?
CommonRustyMullet
@Vlad11, I processed the RMA toward the end of January 2024. I had firmware F9 for Gigabye z790 UD AX, which did not have any of the microcode updates.
Vlad11
Thanks, @CommonRustyMullet , in my case I replaced mine this summer. I installed all the microcode updates as they were released, and it was working fine initially, but now it's unstable again for some reason.
CommonRustyMullet
@Vlad11, I should have mentioned that I found out during my troubleshooting that the motherboard's defaults weren't limiting the CPU to specs, so I had set the Max Current, P1, and P2 to the CPU specs. By then though it was too late for my original CPU. I have run this new one with the BIOS settings at CPU specs since day one, but still have issues as mentioned previously in this thread.
SpeedToaster
@CommonRustyMulletYou probably did not set a voltage limit for your processor, such as the IA VR Voltage limit, before the Intel microcode update. Therefore CPU have voltage spikes while idling which cause degradation. Even setting up Power and Current Limit will not save your from the issue where it is the voltage that killed the CPU.
Angelov
Hello, everyone.
I have a simple question: would I have problems If I bought a brand new 13th or 14th gen CPU and installed it on a motherboard, that's fully patched with the latest microcode (and the right settings activated)?
Eddiebacher
Can this cause your pc not to connect to wifi and Bluetooth?
Bettychan
Hi Intel team,
Thanks for your information below.
I would like to know the possiblity of the symptoms about this Intel RPL Instability issue.
Is thermal error with unexpected reboot considerable symtoms?
Nate6
@Thomas_Hannaford My Alienware Aurora R16 Motherboard is not listed in the compatible products link you posted.
Baseboard Manufacturer: Alienware
Baseboard Product: 0RF96M
Baseboard Version: A01
Current BIOS Version: Alienware 2.16.0
CPU: 14900kf
LinearCod
Just adding to this. My 13900KF seems to be suffering from this, even after the latest bios. I've opened a support ticket to see what options I have. I had to resort back to my older i5 to get my system back up and stable. Really hope something can be done about this since this chip was expensive!
LinearCod
I requested warranty service for my 13900K which failed due to this manufacturer issue. Intel denied it and washed their hands of responsibility. This was the most expensive CPU I have purchased. It is sad to know that a company as big as Intel does not stand behind their flagship products. Looks like I am stuck with my old 12600K. Thanks Intel!
GB55
I purchased 3 Dell XPS 8960 computers and all three of them failed. The first time I thought it was due to a bios update, which bricked all three computers but one of them eventually did a bios recovery and continued to work. The two that failed, I sent in for repair and I think they replaced the mother boards. When I got them back they worked for a short while and now the one that recovered and one of the repaired ones have failed again. I spoke to support and insisted that all three be replaced as there is an obvious defect in these models but they refused. I then requested a lifetime warranty in lieu of replacing them due to the fact that they apparently will continue to fail beyond my warranty period since they are faulty but of course they refused. Now, instead of sending them in, I am waiting for an onsite tech to repair the two failed machines. I believe my computers all have a PRC,RPSR,I7-14700,2.1,65,8C and I'm not really sure what is happening now as I just came in one morning and they simply had black screens with no apparent cause. It may or may not have been another bios issue. I am not sure if the topic of this thread applies to me but it seems likely and I don't know what to do next.
KINOmx
I purchased my Core i7 147000F last april for MSI B670M Gaming Plus WIFI motherboard and it work almost fine for 2 or 3 weeks, then Marvel Rivals started crashing and randomly after the computer started freezing every time more frequent than the last until it wouldn't have passed 5 minutes before it froze. I even tried re-installing Windows 11 and it also froze at different stages.
Was it just bad luck because of the processor I got? Shjould I roll the dice with RMA and hope I don't get another faulty 14th gen Core i7? or could it be other things? I've updated BIOS, disabled C-State alone or C-State and all of the Intel marked options in BIOS. I've tried different brand new NVMes, different RAM slots and just one RAM at the time. Also tried on Windows 10 with no luck.
This crash reporter popped up every time Marvel Rivals crashed (this doesn't happen on my laptop with Intel Core i7 6700HQ and NVidia 1060This crash reporter popped up every time Marvel Rivals crashed (this doesn't happen on my laptop with Intel Core i7 6700HQ and NVidia 1060
DenBRC
I've been researching this issue extensively, since I'm in charge of IT systems at a school and we have many computers with 13th-generation Intel processors. Unfortunately, based on the information I was able to gather, it looks like we've fallen into the same nightmare we experienced back in 2008, when NVIDIA used low-purity copper in their chipsets, which degraded due to oxidation. The oxidation process was accelerated by high temperatures, but even at lower temps, the defective chips would eventually fail.
Back then, the only permanent fix was to replace the chips that contained the contaminated copper — everything else, like BIOS reprogramming or improved cooling, were just short-term band-aids.
From what I’ve come to understand, Intel used low-grade copper in all of its 13th-gen and later processors. What we’re seeing now — high-performance CPU failures — is just the beginning. I’m afraid it’s only a matter of time before all these processors, from desktops to laptops, from high-end to entry-level, start failing. Just like with the NVIDIA situation, I suspect the majority of Intel's 13th and 14th gen processors will eventually fail, with only a few lucky ones surviving.
From this perspective, no microcode update or BIOS tweak is going to fix the issue — not even temporarily. At best, it might slightly delay the inevitable.
The biggest problem is that Intel refuses to acknowledge the issue, and they’re alienating their customer base because of it. For example, I would never recommend Intel again — this flaw is putting my job at risk. I was the one who convinced management to go with Intel-based PCs at my workplace. So when all those machines inevitably start failing, I’ll likely be held responsible.
As proof of my hypothesis, I currently have a friend’s PC on my workbench at home — it’s got an Intel Core i9-14900K. It started having issues right out of the box. The PC was barely used because they could never get it to run properly. No patch, update, or adjustment has fixed it. Clearly, the CPU was defective from the factory — something I had never seen happen with Intel before.
Dreadmoc
Hello Tom,
I'm afraid this has not solved the problem. I purchased my computer in early December 2024 (14900kf). The first thing I did was update the BIOS. From day one the 12B code and "default" settings have been applied and still, the system is unstable.
Disabling Intel Turbo Boost Technology has alleviated some of the systems, but certainly hasn't "fixed" my problem. This CPU is simply not stable and no customer should ever have to research this extensively only to find out there is no solution.
What's even worse is the fact that Intel currently appears to be ignoring this problem entirely. 12B fixed nothing. These very expensive CPUs are slowly dying and Intel is doing nothing to help their customers.
Eruman
Running an i7-13700K in a HP Z2G9 with Windows 11 and starting experiencing intermittent stability issues from about April 2025. Symptoms are a crash to black screen, and maybe 10% of the time a BSOD with CRITICAL_PROCESS_DIED. The frequency of crashes increased from once every other week to 2-3 times a week in July 2025 where I got annoyed enough to start investigating.
I went through a long list of software related troubleshooting (latest drivers etc.), with the official HP patch (https://support.hp.com/gb-en/document/ish_11349067-11349049-16) not resolving the issue.
I had no luck using the BIOS to turn off Turbo Boost, or Extended Idle Power States. Turning off hyperthreading has gotten me about 10 days without a crash, so here's hoping it might help someone!?
Eruman
To follow up on myself - I eventually got another inexplicable crash after 2ish weeks with hyperthreading off. So it seemed to help, but imperfectly.
Currently trialling turning E-cores off entirely, and so far 2 weeks in the clear without a single crash.
KingSwae
I take it that there are no fixes for these crashes yet? I've been doing crazy research on why my pc keeps crashing when I try to play games like World of Warcraft, Diablo and Dragonkin. The only reason I found this forum was thanks to the Dragonkin forum (thankfully).
I have an i7-14700k and I've updated my BIOS and upgraded my graphics card. I've tried all kinds of things I've found and nothing has worked even in the slightest. I see nobody has posted in a while so I was wondering if it was because we found a fix or because nobody was getting any responses? Thank you in advance!
skinnyelephant
Hello fellow strugglers. I am sharing my experience with 13700k hoping to add to the knowledge base.
I built a PC with 13700k and 690z motherboard in 2023. Since day one it was crashing occasionally. I ran multiple stress test for CPU and RAM.
All worked fine. But it would still keep crashing about 1-2 times per week at random times. Before a lot more people began to mass report issues with this generation, I did not suspect CPU as the issue. I would need a very long list to mention every thing I tried trying to fix crashing. I think my last steps were fresh OS reinstall and using a new SSD. My motherboard became a victim of hours of tests as I broke one of the lock mechanisms locking RAM in place and bending a pin CPU on my motherboard while reinstalling AIO.
Eventually, I realized the scale of the issue while reading new reports and articles. That is when I finally requested RMA which was simple and quick. I recall, Intel asked me if I had latest updates from the motherboard which I had, my board received several CPU microcode fixes. But those did not help. It was CPU all along. It was one of the most troublesome CPUs I have ever had in my life. And I fully understand why AMD became so much more popular in this decade.
The thing I regret the most is time I lost doing all sorts of troubleshooting the problem. My second regret is forgetting to remove 2 SSDs from a new motherboard that I returned to Amazon, that was 3tb and my work lost. And the main lesson I got is that when an issue is hard to identify, gathering feedback from other people works best. I mean, it seemed like a fully functional CPU. It gave me no problems except for very occasional, but steady crashes.
If you are having the same problem, AND you did the basic troubleshooting, you should replace this CPU. I
DiddyHo
I spent weeks chasing BSODs, random application crashes, and memory corruption on my i9-14900KF. I finally nailed it down to two degraded P-cores using CoreCycler. I used Claude Code extensively to help me during this process. The diagnostic output below was generated with its help because why type it myself.
The key finding: Intel's own Processor Diagnostic Tool (IPDT) reported PASS on this processor. It cannot detect this defect. Here is why.
IPDT runs all cores simultaneously and checks for general functionality. It verifies the processor can execute instructions, perform floating point operations, and access cache. It does not isolate individual cores and test them
independently. A processor with 22 healthy cores and 2 defective cores will pass IPDT because the healthy cores mask the failures. The test is too short, too general, and not granular enough to detect per-core silicon degradation.
This is precisely why the 13th/14th Gen instability issue went undetected for so long. Intel's own diagnostic tool cannot find it.
CoreCycler with Prime95 is the industry-standard method for identifying this defect. It pins a single-threaded workload to one core at a time and runs sustained mathematical computations that verify the results.
My Results
- 24 cores tested individually in isolation
- Each core ran Prime95 SSE with Huge FFTs (8960K-32768K) for 6 minutes
- 22 cores passed across up to 8 full iterations with zero errors
- Core 4 failed within 11 SECONDS with a fatal computation error. Rounding value was 73727.99999 when expected is less than 0.4. That is off by a factor of 184,000. Reproduced identically on a second run.
- Core 5 crashed the Prime95 process entirely on three separate test runs. The core cannot execute code reliably.
- After disabling cores 4-7 in BIOS, the system has been completely crash-free after weeks of daily BSODs and application crashes.
System Details
- i9-14900KF, no overclocking, no XMP, JEDEC memory, latest BIOS (MSI M.A0), microcode 0x133
- memtest86 clean (4 passes), SFC/DISM clean, chkdsk clean, PSU voltages stable, thermals within spec
- Every other component verified. CPU is the sole cause.
Symptoms Before Diagnosis
- BSODs: 0x50, 0x3B, 0xA. All memory corruption in kernel space.
- Windows Defender crashing repeatedly at random offsets in mpengine.dll
- Desktop Window Manager crashing in ntdll.dll
- Task Manager crashing into unknown module at high memory address
- Crashes at both idle and load, affecting completely unrelated processes
What I Want Intel To Know
Your diagnostic tool gives a clean bill of health to a processor with cores that compute results off by a factor of 184,000. If you are going to require customers to run diagnostics before approving an RMA, the tool needs to do
per-core isolation testing. As it stands, IPDT is worse than useless for this issue. It gives false confidence that the processor is healthy.
I filed my RMA with full CoreCycler logs, BSOD history, and a complete diagnostic report. The first response asked me what other troubleshooting I had tried. Everything was already in the attached report.
If you are experiencing similar instability on a 13th/14th Gen processor and IPDT says PASS, run CoreCycler. It takes a couple of hours and will tell you exactly which cores are damaged.
Tool: https://github.com/sp00n/corecycler
Last, Intel's brand is now damaged to me.  Not just because this happened, but because I have 50 hours down at this point and your tech support processes are terrible.  All I want to do is RMA my processor and back and forth every 3 days trying to tell me to troubleshoot more is just bad.  Just give me an RMA already @Thomas_Hannaford.
