Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
550 Discussions
GLSL compile failed (’GL_3DL_array_objects’ : extension is disabled or not available)
Yuya_Fukazawa_bn7
#version 310 es
precision highp float;
layout(location = 0) out vec4 Output;
void main()
	const float arr[3] = float[3]
		0.0, 0.5, 1.0
	Output = vec4( arr[0], arr[1], arr[2], 1.0 );
The above fragment shader compiles successfully with Intel® Graphics Driver 31.0.101.1692, but fails to compile with Intel® Graphics Driver 31.0.101.5333.
glGetShaderInfoLog returns "ERROR: 2668:38048.581: ’GL_3DL_array_objects’ : extension is disabled or not available".
I think this compile error is a bug in the driver.
I have attached some files.
・Report/GLSLCompilerTest/bin/GLSLCompilerTest.exe is the executable file that compiles the above fragment shader.
・Report/CompileSucceeded_30.0.101.1692.png is an image of a successful compilation with Intel® Graphics Driver 30.0.101.1692.
・Report/CompileFailed_30.0.101.5333.png is an image of failed compilation with Intel® Graphics Driver 31.0.101.5333.
Arturo_Intel
Hello Fukazawa-san:
Please try the 101.6332 driver version (Intel® Arc™ & Iris® Xe Graphics - Windows*)
The missing support of the OpenGL extension was added
-- Arturo Medina
Intel Game Developer support engineer
Arturo_Intel
Isn't this incorrect?
OpenGL 4.5 contains GL_ARB_ES3_1_compatibility.
Do you have any official documentation where this is disclaimed? It could help me to push the issue to the right way.
Using the core profile context (GLSLCompilerTest.exe), the shader compilation fails.
But, using the (GLSLCompilerTest.exe -compat), the shader compiles successfully.
Is this the behavior to expect?
I need to check it with the team.
--r2
Yuya_Fukazawa_bn7
https://registry.khronos.org/OpenGL/specs/gl/glspec45.core.pdf
Appendix H
H.1 New Features (Page 689)
Yuya_Fukazawa_bn7
Hello @Arturo_Intel
Is there any progress on this issue?
Arturo_Intel
Hello Fukazawa-san:
-- Arturo Medina
