Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
This forum offers only peer-to-peer support. Thank you!
Learn more about Developing Games on Intel Graphics
558 Discussions
HDCP support via Windows Output Protection Manager API on Intel HD 530 graphics card
bitsmaker
I am trying to use the Windows Output Manager API (https://msdn.microsoft.com/en-us/library/windows/desktop/dd388980(v=vs.85).aspx) to enable HDCP on an Intel HD 530 graphics card. I am able to call "IOPMVideoOutput::StartInitialization" successfully but "IOPMVideoOutput::FinishInitialization" returns an error stating "HRESULT_FROM_WIN32(ERROR_GEN_FAILURE) : A device attached to the system is not functioning."
I am not sure why this is the case, any help would be appreciated. I have included the results of dxdiag.
Thanks for all your help.
System Information
      Time of this report: 1/20/2017, 15:03:21
             Machine name:
         Operating System: Windows 10 Enterprise 2015 LTSB 64-bit (10.0, Build 10240) (10240.th1_st1.161118-1836)
                 Language: English (Regional Setting: English)
      System Manufacturer: Default string
             System Model: Default string
                     BIOS: Default System BIOS
                Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (8 CPUs), ~2.8GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16306MB RAM
                Page File: 3145MB used, 15592MB available
              Windows Dir: C:\Windows
          DirectX Version: 12
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.10240.16384 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: Intel(R) HD Graphics 530
       Manufacturer: Intel Corporation
          Chip type: Intel(R) HD Graphics Family
           DAC type: Internal
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_8086&DEV_1912&SUBSYS_00008086&REV_06
     Display Memory: 8280 MB
   Dedicated Memory: 128 MB
      Shared Memory: 8152 MB
       Current Mode: 1920 x 1200 (32 bit) (59Hz)
       Monitor Name: Dell U2412M(DisplayPort)
      Monitor Model: DELL U2412M
         Monitor Id: DELA07B
        Native Mode: 1920 x 1200(p) (59.950Hz)
        Output Type: Displayport External
        Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32
Driver File Version: 21.20.0016.4534 (English)
     Driver Version: 21.20.16.4534
        DDI Version: 12
     Feature Levels: 12.1,12.0,11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 2.0
Graphics Preemption: Triangle
 Compute Preemption: Thread
           Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 11/2/2016 13:02:18, 94205376 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B78E66-5A52-11CF-80F2-1020BDC2D835}
          Vendor ID: 0x8086
          Device ID: 0x1912
          SubSys ID: 0x00008086
        Revision ID: 0x0006
 Driver Strong Name: oem28.inf:5f63e53470659c00:iSKLD_w10:21.20.16.4534:pci\ven_8086&dev_1912
     Rank Of Driver: 00D12001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  DXVA2_ModeHEVC_VLD_Main  DXVA2_ModeHEVC_VLD_Main10
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
           DAC type: Internal
         Monitor Id: DELA07B
        DDI Version: 12
        WHQL Logo'd: Yes
    WHQL Date Stamp:
          Vendor ID: 0x8086
          Device ID: 0x1912
        Revision ID: 0x0006
            DXVA-HD: Supported
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description:
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID:
        Manufacturer ID:
             Product ID:
                   Type:
            Driver Name:
         Driver Version:
      Driver Attributes:
            WHQL Logo'd:
          Date and Size:
            Other Files:
        Driver Provider:
         HW Accel Level: Emulation Only
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
            Description: Line In (Realtek High Definition Audio)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7541 (English)
          Date and Size: 6/18/2015 19:45:16, 4496600 bytes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
            Description: Stereo Mix (Realtek High Definition Audio)
  Default Sound Capture: No
  Default Voice Capture: No
              Cap Flags: 0x1
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (xHCI)
| Vendor/Product ID: 0x8086, 0xA12F
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 11/24/2015 22:40:09, 516448 bytes
+-+ USB Input Device
| | Vendor/Product ID: 0x046D, 0xC05A
| | Matching Device ID: USB\Class_03&SubClass_01
| | Service: HidUsb
| | Driver: hidusb.sys, 7/10/2015 03:59:38, 38400 bytes
| | Driver: hidclass.sys, 7/10/2015 03:59:38, 153088 bytes
| | Driver: hidparse.sys, 7/10/2015 03:59:38, 39936 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | Service: mouhid
| | | Driver: mouhid.sys, 7/10/2015 03:59:39, 32256 bytes
| | | Driver: mouclass.sys, 7/10/2015 03:59:39, 59232 bytes
| | Vendor/Product ID: 0x413C, 0x2107
| | Service: HidUsb
| +-+ HID Keyboard Device
| | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | Service: kbdhid
| | | Driver: kbdhid.sys, 7/10/2015 03:59:38, 36864 bytes
| | | Driver: kbdclass.sys, 7/10/2015 03:59:38, 62304 bytes
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 1.7 GB
Total Space: 122.1 GB
File System: NTFS
      Model: TS128GMTS400
System Devices
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_A170&SUBSYS_72708086&REV_31\3&11583659&0&FB
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.10240.17146 (English), 9/29/2016 21:05:18, 80896 bytes
   Driver: C:\Windows\system32\drivers\drmk.sys, 10.00.10240.16384 (English), 7/10/2015 03:59:36, 96768 bytes
   Driver: C:\Windows\system32\drivers\portcls.sys, 10.00.10240.16515 (English), 9/16/2015 22:50:33, 320000 bytes
     Name: Intel(R) 100 Series/C230 Series Chipset Thermal subsystem - A131
Device ID: PCI\VEN_8086&DEV_A131&SUBSYS_72708086&REV_31\3&11583659&0&A2
   Driver: n/a
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_8086&DEV_191F&SUBSYS_20158086&REV_07\3&11583659&0&00
   Driver: n/a
Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\4&2FFDBD31&0&0008
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 10.00.10240.16942 (English), 5/27/2016 22:00:08, 327520 bytes
Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\5&1B9B1C97&0&180008
     Name: Intel(R) 100 Series/C230 Series Chipset SMBus - A123
Device ID: PCI\VEN_8086&DEV_A123&SUBSYS_72708086&REV_31\3&11583659&0&FC
   Driver: n/a
Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\5&1B9B1C97&0&200008
     Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_A12F&SUBSYS_72708086&REV_31\3&11583659&0&A0
   Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 10.00.10240.16461 (English), 8/18/2015 00:55:45, 373072 bytes
     Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_A13A&SUBSYS_19998086&REV_31\3&11583659&0&B0
   Driver: C:\Windows\system32\DRIVERS\TeeDriverW8x64.sys, 11.00.0005.1189 (English), 3/28/2016 22:01:56, 186424 bytes
Device ID: PCI\VEN_111D&DEV_806E&SUBSYS_00000000&REV_02\5&1B9B1C97&0&100008
     Name: Intel(R) 100 Series/C230 Series Chipset Family LPC Controller - A143
Device ID: PCI\VEN_8086&DEV_A143&SUBSYS_72708086&REV_31\3&11583659&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.10240.16384 (English), 7/10/2015 03:59:38, 19296 bytes
Device ID: PCI\VEN_1172&DEV_E001&SUBSYS_2404A106&REV_09\6&1A932327&0&00200008
   Driver: n/a
     Name: Intel(R) Serial IO I2C Host Controller - A160
Device ID: PCI\VEN_8086&DEV_A160&SUBSYS_72708086&REV_31\3&11583659&0&A8
   Driver: C:\Windows\system32\DRIVERS\iaLPSS2_I2C.sys, 30.63.1519.0007 (English), 7/20/2015 14:52:46, 185128 bytes
     Name: Intel(R) 100 Series/C230 Series Chipset PMC - A121
Device ID: PCI\VEN_8086&DEV_A121&SUBSYS_72708086&REV_31\3&11583659&0&FA
   Driver: n/a
     Name: Intel(R) HD Graphics 530
Device ID: PCI\VEN_8086&DEV_1912&SUBSYS_00008086&REV_06\3&11583659&0&10
   Driver: C:\Windows\system32\DRIVERS\igdkmd64.sys, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 11033056 bytes
   Driver: C:\Windows\system32\igd10iumd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 22139072 bytes
   Driver: C:\Windows\system32\igd10idpp64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 433872 bytes
   Driver: C:\Windows\system32\igd11dxva64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 48250120 bytes
   Driver: C:\Windows\system32\igd12umd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 3484120 bytes
   Driver: C:\Windows\system32\igdumdim64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 94205376 bytes
   Driver: C:\Windows\system32\igdail64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 327688 bytes
   Driver: C:\Windows\system32\igfxcmrt64.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 197072 bytes
   Driver: C:\Windows\system32\igfx11cmrt64.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 194512 bytes
   Driver: C:\Windows\system32\igfxcmjit64.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 2324496 bytes
   Driver: C:\Windows\system32\igdde64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 224784 bytes
   Driver: C:\Windows\system32\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 11/2/2016 13:02:18, 480224 bytes
   Driver: C:\Windows\system32\igdusc64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 6628128 bytes
   Driver: C:\Windows\system32\iga64.dll, 11/2/2016 13:02:11, 1349776 bytes
   Driver: C:\Windows\system32\igc64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 18608480 bytes
   Driver: C:\Windows\system32\igdmd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 2922488 bytes
   Driver: C:\Windows\system32\igxpun.exe, 1.07.0022.0000 (English), 11/2/2016 13:02:18, 1019872 bytes
   Driver: C:\Windows\SysWow64\igd10iumd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 17333920 bytes
   Driver: C:\Windows\SysWow64\igd10idpp32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 411888 bytes
   Driver: C:\Windows\SysWow64\igd11dxva32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 47370208 bytes
   Driver: C:\Windows\SysWow64\igd12umd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 3384536 bytes
   Driver: C:\Windows\SysWow64\igdumdim32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:14, 92943584 bytes
   Driver: C:\Windows\SysWow64\igdail32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 308232 bytes
   Driver: C:\Windows\SysWow64\igdde32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 183896 bytes
   Driver: C:\Windows\SysWow64\igfxcmrt32.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 170712 bytes
   Driver: C:\Windows\SysWow64\igfx11cmrt32.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 170800 bytes
   Driver: C:\Windows\SysWow64\igfxcmjit32.dll, 6.00.0000.1189 (English), 11/2/2016 13:02:18, 1711624 bytes
   Driver: C:\Windows\SysWow64\igdusc32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 5090168 bytes
   Driver: C:\Windows\SysWow64\iga32.dll, 11/2/2016 13:02:11, 1119216 bytes
   Driver: C:\Windows\SysWow64\igc32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:12, 15921728 bytes
   Driver: C:\Windows\SysWow64\igdmd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 2273048 bytes
   Driver: C:\Windows\SysWow64\iglhcp32.dll, 9.00.0030.7777 (English), 11/2/2016 13:02:18, 203312 bytes
   Driver: C:\Windows\SysWow64\iglhsip32.dll, 9.00.0030.9000 (English), 11/2/2016 13:02:18, 1814072 bytes
   Driver: C:\Windows\SysWow64\IntelCpHeciSvc.exe, 9.00.0031.9015 (English), 11/2/2016 13:02:18, 301536 bytes
   Driver: C:\Windows\system32\iglhxs64.vp, 11/2/2016 13:02:18, 12742 bytes
   Driver: C:\Windows\system32\iglhxo64.vp, 11/19/2015 19:55:42, 40343 bytes
   Driver: C:\Windows\system32\iglhxc64.vp, 11/19/2015 19:55:42, 40316 bytes
   Driver: C:\Windows\system32\iglhxg64.vp, 11/19/2015 19:55:42, 39658 bytes
   Driver: C:\Windows\system32\iglhxo64_dev.vp, 11/19/2015 19:55:42, 40931 bytes
   Driver: C:\Windows\system32\iglhxc64_dev.vp, 11/19/2015 19:55:42, 41296 bytes
   Driver: C:\Windows\system32\iglhxg64_dev.vp, 11/19/2015 19:55:42, 39798 bytes
   Driver: C:\Windows\system32\iglhxa64.vp, 11/19/2015 19:55:42, 1125 bytes
   Driver: C:\Windows\system32\iglhxa64.cpa, 11/19/2015 19:55:42, 2813952 bytes
   Driver: C:\Windows\system32\iglhcp64.dll, 9.00.0030.7777 (English), 11/2/2016 13:02:18, 238904 bytes
   Driver: C:\Windows\system32\iglhsip64.dll, 9.00.0030.9000 (English), 11/2/2016 13:02:18, 1816720 bytes
   Driver: C:\Windows\system32\cp_resources.bin, 11/2/2016 13:02:11, 560260 bytes
   Driver: C:\Windows\system32\difx64.exe, 1.04.0003.0000 (English), 11/2/2016 13:02:11, 175072 bytes
   Driver: C:\Windows\system32\igfxDH.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 923656 bytes
   Driver: C:\Windows\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 115208 bytes
   Driver: C:\Windows\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 123912 bytes
   Driver: C:\Windows\system32\igfxDI.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 396296 bytes
   Driver: C:\Windows\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 29704 bytes
   Driver: C:\Windows\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 29200 bytes
   Driver: C:\Windows\system32\igfxLHM.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 1988104 bytes
   Driver: C:\Windows\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 22536 bytes
   Driver: C:\Windows\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 22536 bytes
   Driver: C:\Windows\system32\igfxSDK.exe, 11/2/2016 13:02:18, 992736 bytes
   Driver: C:\Windows\system32\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 97288 bytes
   Driver: C:\Windows\system32\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 107528 bytes
   Driver: C:\Windows\system32\igfxEM.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 523232 bytes
   Driver: C:\Windows\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 27656 bytes
   Driver: C:\Windows\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 11/2/2016 13:02:18, 27656 bytes
   Driver: C:\Windows\system32\GfxUIEx.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:11, 458720 bytes
   Driver: C:\Windows\system32\Gfxv4_0.exe, 8.15.0010.4534 (English), 11/2/2016 13:02:11, 912864 bytes
   Driver: C:\Windows\system32\Gfxv4_0.exe.config, 11/19/2015 19:55:20, 935 bytes
   Driver: C:\Windows\system32\Gfxv2_0.exe, 8.15.0010.4534 (English), 11/2/2016 13:02:11, 907232 bytes
   Driver: C:\Windows\system32\Gfxv2_0.exe.config, 11/19/2015 19:55:20, 895 bytes
   Driver: C:\Windows\system32\GfxResources.dll, 8.15.0010.4534 (English), 11/2/2016 13:02:11, 5056520 bytes
   Driver: C:\Windows\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 11/2/2016 13:02:18, 640008 bytes
   Driver: C:\Windows\system32\igfxCUIServicePS.dll, 11/2/2016 13:02:18, 102920 bytes
   Driver: C:\Windows\system32\igfxCUIService.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 341984 bytes
   Driver: C:\Windows\system32\igfxCPL.cpl, 11/2/2016 13:02:18, 271368 bytes
   Driver: C:\Windows\system32\igfxDTCM.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 208392 bytes
   Driver: C:\Windows\system32\igfxext.exe, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 302560 bytes
   Driver: C:\Windows\system32\igfxexps.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 55248 bytes
   Driver: C:\Windows\system32\ColorImageEnhancement.wmv, 11/19/2015 19:55:16, 375173 bytes
   Driver: C:\Windows\system32\ImageStabilization.wmv, 11/19/2015 19:55:42, 403671 bytes
   Driver: C:\Windows\system32\FilmModeDetection.wmv, 11/19/2015 19:55:20, 641530 bytes
   Driver: C:\Windows\SysWow64\igfxexps32.dll, 6.15.0010.4534 (English), 11/2/2016 13:02:18, 52744 bytes
   Driver: C:\Windows\system32\ig9icd64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:11, 13801992 bytes
   Driver: C:\Windows\SysWow64\ig9icd32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:11, 10542600 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 11/19/2015 19:55:46, 1981 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 11/19/2015 19:55:48, 9788 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 11/2/2016 13:02:19, 32 bytes
   Driver: C:\Windows\SysWow64\Intel_OpenCL_ICD32.dll, 2.01.0000.0000 (English), 11/2/2016 13:02:18, 104464 bytes
   Driver: C:\Windows\SysWow64\IntelOpenCL32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 325640 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 378376 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 8677392 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1470984 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 525328 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 11/2/2016 13:02:19, 1304100 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 11/2/2016 13:02:19, 321224 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 11/2/2016 13:02:19, 392476 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 11/2/2016 13:02:19, 1242036 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 11/2/2016 13:02:19, 312484 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 11/2/2016 13:02:19, 392356 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 11/2/2016 13:02:19, 897152 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 11/2/2016 13:02:19, 263856 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 11/2/2016 13:02:19, 350160 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1427464 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5022728 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5360136 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5238280 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 274088 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 436392 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 11/2/2016 13:02:19, 356000 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 11/2/2016 13:02:19, 1066888 bytes
   Driver: C:\Windows\system32\Intel_OpenCL_ICD64.dll, 2.01.0000.0000 (English), 11/2/2016 13:02:18, 113672 bytes
   Driver: C:\Windows\system32\IntelOpenCL64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:18, 427536 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 434696 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 11609096 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1711112 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 671240 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 11/2/2016 13:02:19, 1251848 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 11/2/2016 13:02:19, 344208 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 11/2/2016 13:02:19, 407884 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 11/2/2016 13:02:19, 1189792 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 11/2/2016 13:02:19, 331136 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 11/2/2016 13:02:19, 407764 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 11/2/2016 13:02:19, 829680 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 11/2/2016 13:02:19, 283240 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 11/2/2016 13:02:19, 365936 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 6.06.0000.0359 (English), 11/2/2016 13:02:19, 1869832 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5234184 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5744648 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.04.0000.0000 (English), 11/2/2016 13:02:19, 5627400 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 323752 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.03.2015.0528 (English), 11/2/2016 13:02:19, 521896 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 11/2/2016 13:02:19, 433824 bytes
   Driver: C:\Windows\SysWow64\igdbcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 412168 bytes
   Driver: C:\Windows\SysWow64\igdrcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 6386192 bytes
   Driver: C:\Windows\SysWow64\common_clang32.dll, 4.03.0006.0427 (English), 11/2/2016 13:02:11, 24667664 bytes
   Driver: C:\Windows\SysWow64\igdmcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 4840456 bytes
   Driver: C:\Windows\SysWow64\igdfcl32.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 239112 bytes
   Driver: C:\Windows\system32\igdbcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 460808 bytes
   Driver: C:\Windows\system32\igdrcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 7089672 bytes
   Driver: C:\Windows\system32\common_clang64.dll, 4.03.0006.0427 (English), 11/2/2016 13:02:11, 36624904 bytes
   Driver: C:\Windows\system32\igdmcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 6886920 bytes
   Driver: C:\Windows\system32\igdfcl64.dll, 21.20.0016.4534 (English), 11/2/2016 13:02:13, 279048 bytes
   Driver: C:\Windows\system32\igdclbif.bin, 11/2/2016 13:02:13, 8096666 bytes
   Driver: C:\Windows\SysWow64\libEGL.dll, 11/2/2016 13:02:18, 141320 bytes
   Driver: C:\Windows\SysWow64\libGLESv1_CM.dll, 11/2/2016 13:02:18, 101384 bytes
   Driver: C:\Windows\SysWow64\libGLESv2.dll, 11/2/2016 13:02:18, 112136 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.16.0009.0019 (English), 11/2/2016 13:02:18, 8838456 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.16.0009.0019 (English), 11/2/2016 13:02:18, 4719320 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1478096 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1368792 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1378520 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1378520 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1493336 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 11/2/2016 13:02:11, 65737 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 11/2/2016 13:02:11, 64141 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 11/19/2015 19:55:20, 846855 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 11/2/2016 13:02:11, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 11/2/2016 13:02:11, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 11/2/2016 13:02:19, 59421 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.16.0009.0019 (English), 11/2/2016 13:02:18, 9272792 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.16.0009.0019 (English), 11/2/2016 13:02:18, 4886752 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1835544 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1699552 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1708760 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1709280 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.16.0009.0026 (English), 11/2/2016 13:02:18, 1860784 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 11/2/2016 13:02:11, 13761 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 11/2/2016 13:02:11, 13141 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 11/19/2015 19:55:20, 1519616 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 11/2/2016 13:02:11, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 11/2/2016 13:02:11, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 11/2/2016 13:02:19, 12621 bytes
   Driver: C:\Windows\system32\igfxCoIn_v4534.dll, 1.03.0020.0000 (English), 11/2/2016 13:02:18, 220168 bytes
   Driver: C:\Windows\system32\DisplayAudiox64.cab, 11/2/2016 13:02:11, 908485 bytes
     Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911
Device ID: PCI\VEN_8086&DEV_1911&SUBSYS_20158086&REV_00\3&11583659&0&40
   Driver: n/a
     Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_A102&SUBSYS_72708086&REV_31\3&11583659&0&B8
   Driver: C:\Windows\system32\DRIVERS\storahci.sys, 10.00.10240.16384 (English), 7/10/2015 03:59:39, 133984 bytes
     Name: Intel(R) Serial IO UART Host Controller - A127
Device ID: PCI\VEN_8086&DEV_A127&SUBSYS_72708086&REV_31\3&11583659&0&F0
   Driver: C:\Windows\system32\DRIVERS\iaLPSS2_UART2.sys, 30.63.1519.0007 (English), 7/20/2015 14:52:46, 281896 bytes
     Name: Intel(R) I210 Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_1533&SUBSYS_00000000&REV_01\6&287B87F&0&00180008
   Driver: C:\Windows\system32\DRIVERS\e1r65x64.sys, 12.12.0226.0000 (English), 4/21/2015 01:02:28, 486344 bytes
   Driver: C:\Windows\system32\e1r65x64.din, 5/4/2015 17:23:10, 3096 bytes
   Driver: C:\Windows\system32\NicCo4.dll, 4.02.0003.0000 (English), 4/18/2014 13:17:32, 125728 bytes
   Driver: C:\Windows\system32\NicInE1R.dll, 9.12.0010.0000 (English), 2/25/2015 04:23:58, 89872 bytes
   Driver: C:\Windows\system32\e1rmsg.dll, 10.00.0417.0000 (English), 4/2/2015 04:46:38, 75288 bytes
     Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
Device ID: PCI\VEN_8086&DEV_1901&SUBSYS_20158086&REV_07\3&11583659&0&08
     Name: Intel(R) Ethernet Connection (2) I219-LM
Device ID: PCI\VEN_8086&DEV_15B7&SUBSYS_00008086&REV_31\3&11583659&0&FE
   Driver: C:\Windows\system32\DRIVERS\e1d65x64.sys, 12.13.0017.0007 (English), 8/13/2015 02:14:46, 531424 bytes
   Driver: C:\Windows\system32\e1d65x64.din, 8/13/2015 02:13:12, 3130 bytes
   Driver: C:\Windows\system32\NicInstD.dll, 9.12.0013.0000 (English), 6/17/2015 01:28:44, 90608 bytes
   Driver: C:\Windows\system32\e1dmsg.dll, 10.00.0417.0000 (English), 4/2/2015 04:46:38, 75288 bytes
     Name: Intel(R) Serial IO I2C Host Controller - A161
Device ID: PCI\VEN_8086&DEV_A161&SUBSYS_72708086&REV_31\3&11583659&0&A9
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.10240.16644
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.10240.16644
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.10240.16644
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.10240.16644
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.10240.16644
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.10240.16644
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.10240.17113
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.10240.16644
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.10240.16644
DV Muxer,0x00400000,0,0,qdv.dll,10.00.10240.16384
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.10240.17113
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.10240.16384
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.10240.17113
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.10240.17113
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.10240.16384
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.10240.16635
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.10240.16384
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.10240.16384
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.10240.17113
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.10240.17113
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.10240.16384
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.10240.16384
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.10240.16384
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.10240.16384
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10240.16644
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.10240.17113
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.10240.17113
DV Splitter,0x00600000,1,2,qdv.dll,10.00.10240.16384
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.10240.17113
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.10240.16644
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.10240.17113
Video Renderer,0x00800001,1,0,quartz.dll,10.00.10240.17113
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.10240.16384
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.10240.17113
Video Renderer,0x00400000,1,0,quartz.dll,10.00.10240.17113
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.10240.16384
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.10240.16384
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,10.00.10240.16384
File writer,0x00200000,1,0,qcap.dll,10.00.10240.16384
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.10240.16644
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10240.16644
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.10240.16384
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.10240.16384
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.10240.16384
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.10240.16644
Null Renderer,0x00200000,1,0,qedit.dll,10.00.10240.16644
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.10240.16384
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.10240.16384
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.10240.16384
Smart Tee,0x00200000,1,2,qcap.dll,10.00.10240.16384
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.10240.17113
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.10240.17113
Wave Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.10240.17113
File stream renderer,0x00400000,1,1,quartz.dll,10.00.10240.17113
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.10240.16635
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.10240.16384
AVI Mux,0x00200000,1,0,qcap.dll,10.00.10240.16384
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.10240.17113
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.10240.17113
File Source (URL),0x00400000,0,1,quartz.dll,10.00.10240.17113
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.10240.16384
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.10240.17113
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.10240.16384
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.10240.17113
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.10240.16644
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.10240.16644
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.10240.16644
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.10240.16644
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.10240.16384
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.10240.17113
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.10240.16644
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.10240.16644
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.10240.17113
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.10240.17113
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.10240.17113
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.10240.17113
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.10240.17113
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.10240.17113
Audio Capture Sources:
Line In (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.10240.16384
Stereo Mix (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.10240.16384
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.10240.17113
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.10240.17113
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.10240.17113
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.10240.17113
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.10240.17113
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.10240.16644
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.10240.16644
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.10240.16644
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.10240.16644
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.10240.16384
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.10240.16384
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.10240.16384
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.10240.17113
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.10240.17113
PTFilter,0x00200000,0,0,EncDec.dll,10.00.10240.17113
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.10240.17113
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.10240.17113
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.10240.17113
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.16.0009.0026
  Intel® Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.16.0009.0026
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.10240.16635
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.10240.16384
  Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.10240.17202
  Intel® Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.16.0009.0026
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.10240.16644
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.10240.16635
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.10240.16644
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.10240.17113
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.10240.16384
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.10240.16644
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.10240.16644
Video Encoders:
  Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.16.0009.0026
  Intel® Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 7.16.0009.0026
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.10240.16644
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.10240.16644
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.10240.16384
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.10240.16644
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.10240.16644
  H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.10240.16384
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.10240.16644
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.10240.16644
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.10240.16384
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.10240.16644
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.10240.16644
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.10240.16384
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.10240.16384
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.10240.16384
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.10240.16644
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.10240.16384
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.10240.17202
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.10240.17202
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.10240.16644
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.10240.16384
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.10240.16384
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.10240.16644
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.10240.17202
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.10240.17202
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.10240.16644
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.10240.16384
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.10240.17202
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, winmde.dll, 12.00.10240.17146
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.10240.17202
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.10240.16384
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.10240.16644
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.10240.16384
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.10240.16644
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.10240.16644
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.10240.16384
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.10240.16384
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.10240.16384
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.10240.16644
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.10240.16644
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.10240.16412
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.10240.16635
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
