Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
550 Discussions
How to assign dedicated graphic memory
Khalil_S_
I am having Intel HD 4400 graphics, it has shared memory of 4182MB but dedicated only 128MB ,any way to allocated it to dedicated memory ??
Khalil_S_
Any help appreciated .
Michael_C_Intel2
128MB is the  pre-allocated memory at system boot. Memory will dynamically increase based on need up to the max DVMT set in system BIOS. You can increase the initial and max DVMT in BIOS on most OEM systems. Integrated graphics share memory with the rest of the system. The more pre-allocated for graphics the less the rest of the system will have. Altering the pre-allocated memory will not change graphics performance.
Sahan_K_
is there any need of driver updates to get the full use
Michael_C_Intel2
No driver update is required make these changes as it is a system BIOS level change.
