Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
This forum offers only peer-to-peer support. Thank you!
Learn more about Developing Games on Intel Graphics
554 Discussions
Memory size to HD3000 for 32bit or 64 bit system
magicfoot
If I convert my Windows to run 64bit instead of 32bit, can I allocate a lot more memory to the HD3000? Is this a programatically configurable option or is this hard set by the bios.
MPere15
"If I convert my Windows to run 64bit instead of 32bit, can I allocate a lot more memory to the HD3000?"
I don't think so. Maximum memory is 1.7GB, and you don't need 64bit for that.
You may even end with less available video memory. The heavier the operating system, the less the amount of free memory available for the video ram.
"Is this a programatically configurable option or is this hard set by the bios."
The amount of graphics memory in use is dynamically allocated by the chipset, so I don't think you can change this.
Please check:
Graphics memory frequently asked questions
http://www.intel.com/support/graphics/sb/CS-029090.htm
Hope that helps.
