Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
This forum offers only peer-to-peer support. Thank you!
Learn more about Developing Games on Intel Graphics
551 Discussions
OpenGL procedurally generated night nebula shader malfunctioning in Minecraft.
djmrFunnyMan
New Contributor II
This is a continuation from https://community.intel.com/t5/Developing-Games-on-Intel/Driver-level-bugs-causing-issues-in-Minecraft-amp-OpenGL-shaders/td-p/1664368 which will be split into 3 separate reports.
Issue:
Night Nebula function from Complementary Shaders is broken on certain nights.
This issue also isn't present on Nvidia or AMD cards.
The function that drives this effect is located in nightNebula.glsl (in the attached shaderpacks.zip)
(3 showcase images attached)
Reproduction Steps
Preparation:
- Install Iris & Sodium for 1.21.4 : https://github.com/IrisShaders/Iris/blob/multiloader-new/docs/guide.md
- Unpack the shaderpacks.zip inside the (...)\AppData\Roaming\.minecraft folder
- Unpack the Driver Bug Test.zip inside the \AppData\Roaming\.minecraft\saves folder
- Go into options>video settings>shaderpacks and select "complementary unbound 5.4 + euphoria patches 1.5.2"
- Press apply
Reproduction:
- Open the Driver Bug Test world in-game
- Step on the pressure plate that says "Broken Night Sky"
- Step on any of the pressure plates and you should notice graphical issues on the sky
karen_intel
@djmrFunnyMan noted!
Adding to debug queue
Karen
