Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
550 Discussions
Texturing problem on Mobile GMA X3100
dnutsch
We are developing an application for the GMA X3100 and have had users experience corrupted images. We haven't been able to pinpoint the cause in the code, so if you have any suggestions they would be appreciated.
Description
Our application is using OpenGL. This problem doesn't appear on nVidia, ATI, or older Intel mobile processors and has only appeared when we began using the X3100. We have the latest drivers from 8-10-07, which did not fix the problem.
As you can see this is a room scene with a repeated texture across the wall. There seems to be a problem with texture addressing. Instead of repeating the wall texture, a larger chunk of video memory is used. The texture is mip-mapped and you can see the other detail levels stacked within the larger chunk. Other geometry parts such as the window shade, are not textured at all, but are still rendered incorrectly with a garbage texture (purple).
If you have any ideas, please post them.
dnutsch
For anyone who is interested, this is the result of XP laptops going into standby mode. When the machines wake up from standby, the textures are corrupted. We have also seen this with a mobile Intel 915GM machine.
Chuck_De_Sylva
Can you send me an email? We might need to reproduce on our end so if you can send just the binaries that would help also.
Chuck
