Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
550 Discussions
need for speed games (frostbite engine issues) 2015 and later as well as forza horizon 5
SSR49
Graphics driver version - 31.0.101.3413 generic, not OEM
Forza horizon 5 - steam installation
weird black spots on ground textures
Need for speed 2015 - steam installation
issue with rendering car interiors, white steering wheel, animated steering wheel sometimes comes out the window when turning your car
Need for speed payback - steam installation
performance issues (lag & stuttering)
driver glitches (tailights show incorrect colour, often bright/white in colour)
Need for speed heat - steam installation
performance issues (lag & stuttering especially in cutscenes and intro cutscene when opening game and loading in the map when driving)
extremely high gpu usage or presumably thermals caused system to have issues (processor suddenly drops to 0.38 ghz momentarily with an almost unusable system)
arun_intel
Hi @SSR49 ,
Could you run the SSU tool (SSU Tool)on the target system and attach the log for our reference?
SSR49
ran SSU and saved the details to a text document
SSR49
arun_intel
Hi @SSR49 ,
Please verify the issue on the latest graphics driver version available 31.0.101.3790 and let me know the observations.
We will stay tuned for your updates.
Arun_intel
SSR49
issue still persistent, heres another clip for reference in nfs heat where the textures dont properly load in and white tail lights
SSR49
forza h5 still having its texture issues as well, sometimes with completely black ground textures when closely rendered, alongside the issue already mentioned before
SSR49
i also tried with updated OEM driver, still not working
AnaWilliam850
I have the same issue, someone could find a solution to this problem?
karen_intel
Hi all
Thank you for sharing your findings. Unfortunately we have not been able to replicate this behavior in Forza Horizon/Need for Speed.
We need more information about the resolution you're running in.
Can you please share a SS of the Settings Menu/Resolution/FPS you're running in and make sure to be using the latest driver for your Intel Product?
We appreciate your efforts by helping us following this behavior, keep us posted
Karen
SSR49
@karen_intel  Tried the latest OEM and generic drivers again, the resolution for forza and nfs were 1440 X 900 when testing. experiencing the same exact issues again, nothing changed. This seems to be problem with intel Xe graphics and other intel iGPUs but ive found that this is not the case with AMD or Nvidia (so the issue is likely not lack of driver support in the games)
