Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
Clients are OFFLINE in CSL manager dashboard
Snehal_Yesugade
HI
The clients which were ONLINE running earlier, suddenly went OFFLINE.
This might be due to changes in network bridge interfaces.
I want to know how to identity which all the interfaces are used in orchestration.
Need help
Haizad_Intel
This issue was caused by running firewalld command which overwrite iptables settings.
Run the following commands to enable the ports again:
$ sudo iptables -I INPUT -i lo -j ACCEPT
$ sudo iptables -I OUTPUT -o lo -j ACCEPT
$ sudo iptables -I OUTPUT -m state --state ESTABLISHED -j ACCEPT
$ sudo iptables -I INPUT -m state --state ESTABLISHED -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 8443 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 6444 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 6443 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 2379 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 2380 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 10250 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 6783 -j ACCEPT
$ sudo iptables -I INPUT -p udp --dport 6783 -j ACCEPT
$ sudo iptables -I INPUT -p udp --dport 6784 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 5000 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --dport 5001 -j ACCEPT
$ sudo iptables -I INPUT -p tcp --match multiport --dports 30000:32767 -j ACCEPT
$ sudo iptables -I INPUT -p udp --match multiport --dports 30000:32767 -j ACCEPT
Haizad_Intel
