Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Dropped support for ethercat igc?
grandixximo
I went to do an update to my ECI setup, checking the difference for the ethercat.conf
seems like the igc drive has been removed from the Possible Values?
Why is this? i225 IGC is still listed as recommended hardware in the 3.3 docs
Why is support being dropped? why are you removing components that you previously recommended, has there been any notice about this?
Peh_Intel
Hi Grandixximo,
We have tested on our machine and able to enable ethercat with igc driver. We used the instructions in IgH EtherCAT Master Stack — ECI documentation after installing Linux Intel LTS PREEMPT_RT kernel using the apt installation instructions.
Please try again and let us know if you has any issues. If you runs into any issues, please provide the steps you took and the output of lspci | grep Ethernet.
Peh
Aznie_Intel
Hi Grandixximo,
Thanks for reaching out. I will escalate this to our engineering team to get clarification on the removal of the igc driver from the EtherCAT configuration. We are investigating whether this change was intentional and if there are any recommended alternatives. I’ll provide an update as soon as I receive more details. Please let me know if you have any specific concerns in the meantime.
Aznie
grandixximo
Hi Aznie,
Thank you for your reply, the only concern is about the igc drive situation, and if there is/was any blog or newsletter that I missed about this, it's not really enticing to use something for which support could be dropped without notice.
grandixximo
grandixximo
patiently waiting for a reply...
grandixximo
Hello, anyone seeing this?
Aznie_Intel
Hi Grandixximo,
Thank you for your patience. We confirmed with the development team that EtherCAT IGC is supported in ECI 3.3 and have updated the documentation accordingly.
Aznie
grandixximo
That's good to know. the igc is still not being reinstated in the /etc/ethercat.conf and /etc/sysconfigs/ethercat files, please check both.
and loading the igc drive gives a kernel bug in dmesg, not much works after boot, sudo is not working, and many other applications are non responsive, loading with generic drive works, but generic does not have the same performance as igc, since you are wanting to support igc please test and fix it
Aznie_Intel
Hi Grandixximo,
We will investigate this further and escalate the issue to the engineering team for resolution. We appreciate your feedback and will provide updates as soon as possible.
Aznie
Peh_Intel
Hi Grandixximo,
Peh
Aznie_Intel
Hi Grandixximo,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question
Aznie
