Edge Software Catalog
488 Discussions
ECI (ESDQ) no esdq command question
Geen
Dear Sir
I refer to the following information to install the ESDQ,
https://www.intel.com/content/www/us/en/developer/articles/guide/edge-software-device-qualification.html
You can see the ESDQ install success information as below:
***Recommended to reboot system after installation***
|            Id            | Module |  Status |
| 64cb337f89c314c29867e05c |  ESDQ  | SUCCESS |
Until i do the below step , i can not find the esdq binary.......
Do you have suggestion about it ?
Run the Application
NOTE:
Download and install Intel® ESDQ with the respective test modules before you continue in this section.
Perform the following procedure to run Intel® ESDQ as a complete test suite via the esdq CLI.
  1. Change the directory to the location of Intel® ESDQ.
cd ~/esdq
Check the Intel® ESDQ version.
esdq --version
Ensure the release version matches the version you downloaded. Here's an example of the output.
Geen
Add more information
edgesoftware , version 2024.1
SShan_Intel
Hi Green,
For ESDQ ECI installation, refer to this documentation https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-eci.html
The documentation that you referring to is general ESDQ page, it does not have ECI features.
SShan_Intel
Wan_Intel
Hi SShan_Intel,
Thanks for sharing your answer in Intel® Edge Software Hub Community.
Hi Geen,
Referring to the answer provided by SShan_Intel, does installing Intel® Edge Software Device Qualification (Intel® ESDQ) for Intel® Edge Controls for Industrial (Intel® ECI) resolve your issue?
Wan
Geen
Dear Wan_Intel & SShan_Intel
Thanks for your information.
This issue is already resolved.
Wan_Intel
Hi Geen,
We are glad to know that your issue has been resolved. We will close this case now. If you need additional information from Intel, please submit a new question.
Wan
