Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
EDTDT package install issues
Jerry4_Liu
Hello all,
The text on the intel official website say:
EDTDT package and its test module dependencies will be enlisted in the edgesoftware-configuration.xml when the customer selects the option. ESH CLI will use the same mechanism to download and install the EDTDT components and test suite onto the target system with the other package components.
So,
Can we choose our test module or which software package to install?
Can we remove Intel Vision Accelerator Test Suite?  Will it cause any problems?
-Jerry
Nadia_J_Intel
Hi Jerry,
Yes, you can edit the edgesoftware_configuration.xml file and remove the line that you do not want to install. But for example, if you remove the Vision Test Module, the visiontest result will no longer will be listed when the edtdt report is generated later.
Nadia
Jerry4_Liu
OK~ I see~
thank you for responding~
