Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
EI AMR installation invalid key
pdoshi
I have downloaded the EI AMR in Ubantu 20.04. the installation key provided via email is not working somehow.
JesusE_Intel
Hi Parth,
Please let me know if you continue to see the error message when running the installer on and off the VPN. If you could please share a screenshot of what you are seeing.
Jesus
JesusE_Intel
Hi pdoshi,
Thanks for reaching out. The product key should include the dashes when prompted by the installer. Are you including the dashes in the product key? What error message do you see? Are you installing by downloading the zip file or with the pip command? Are you behind a firewall?
I just tested on Ubuntu 20.04 using both zip file and pip install method and my product key was accepted.
Jesus
pdoshi
Hi Jesus,
Thanks for a prompt reply.
yes i am including dash in between the keys
i am installing EI via pip command. i have connected the vpn as well.
I will in the meantime try to run the installation again.
However, one day before the key was accepted and there were some proxy issue.
but since yesterday, i am getting an error saying invalid product key
Parth
JesusE_Intel
Hi Parth,
Jesus
JesusE_Intel
