Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
EII Time Series package install failed
yi15
This in inquiry about EII install. I can't install eii installr as atachement.
Could you tell me which file I should check to how to write the following.
# Please populate the below EII DB and UI credentials needed for EII installation. Based on the EII services
# coming up, the below credentials would be used
etcdroot_password:
influxdb_username:
influxdb_password:
minio_access_key:
minio_secret_key:
JesusE_Intel
Hi yi15,
These are values you are defining, Influxdb username and password are used to initialize the database in the datastore microservice. Additional information can be found here: https://eiidocs.intel.com/4.1/pages/getting-started-guide.html#step-4-configure-your-installation
Jesus
JesusE_Intel
Hi yi15,
Thanks for reaching out, the values need to be specified in ~/edge_insights_industrial/config_install.yml. It should be located in the same directory as the edgesoftware binary. In the screenshot above, you are displaying the content of config_install.yml file, just complete the lines.
For example:
etcdroot_password: 'password'
influxdb_user: 'user'
Jesus
yi15
Hi Jesus,
Thank you for your reply. To set value in ~/edge_insights_industrial/config_install.yml, Shoul I get influxdb_user and pass for third party ? Or Is there this value in other files?
JesusE_Intel
Hi yi15,
Jesus
yi15
Thank you for your support.
I remembered that etcd password is optional but EIF requires this password as mandatory. Or May I set the blank as "" ?
JesusE_Intel
