Edge Software Catalog
485 Discussions
EIS Ingestion Issues on EC2
kranthi_volteo
We are trying to set up an EIS stack in cloud EC2 Ubuntu 18.04 servers. We are seeing some issues with ingestion, tried various servers, still see the same.. Let me know if we are missing anything.  Works perfectly fine on dev ubuntu machines. Should we use any specific EC2 servers. we currently tested on c3.4xlarge and c4.8xlarge instance types.
kranthi_volteo
Hi Weng,
      Thanks for the info. I am using AWS EC2 machine without GPU, so gstreamer plugin did not work. I switched to opencv plugin. It works.
WengWai_C_Intel
Hi @kranthi_volteo ,
Kindly provide below information for further understand your setup:
1) Provide full configuration for video ingestion, you can screenshot it from ETCD web UI.
2) Which Intel CPU running on the EC2 server? You can use command "lscpu" to check and provide the info. Is the Intel CPU also came with Intel integrated GPU?
thanks!
kranthi_volteo
Hi Weng,
WengWai_C_Intel
Yes, that is what i am suspecting so i am trying to confirm your full config of video ingestion and your hardware spec if come with iGPU to validate my hypothesis. It is great now you can get EIS running on AWS EC2 server. Thanks!
