Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
ERROR: Service 'tls_apiui' failed to build
HuynhVanThuan
I'm having problems installing TLS when I executed the "./setup_TLS_docker.sh" command but systems gives me the following error message:
/bin/sh: 1: npm: not found
ERROR: Service 'tls_apiui' failed to build: The command '/bin/sh -c npm install serve' returned a non-zero code: 127
I don't understand the problem I'm having. Can you help me?
I am using Ubuntu OS version 18.04.06
Regard,
Huynh
HuynhVanThuan
Hi JeusE,
I'm not sure about the error I got but somehow it didn't give the same error when I was installing on another computer with the same version installed
Regard,
Huynh
JesusE_Intel
Hi Huynh,
I just installed Edge Insights for Industrial 2.6.3 and ran setup_TLS_docker.sh without any issues. Could you please check your internet connection and re-run the script?
Jesus
HuynhVanThuan
Hi JesusE,
i used to get this error but it solved when i upgrade Ubuntu OS to 20.04 version but i get this problem every time i use 18.04.06 version. I want to go back to version 18.04.xx because it is the recommended Ubuntu OS according to the manual. So can I know the exact OS you are using? I think some version you are using in 18.04.xx will solve my problem.
Regard,
Huynh
JesusE_Intel
Hi Huynh,
I am using Ubuntu 18.04.1. However, the system requirements lists Ubuntu 18.04.3 LTS. Let me install the LTS version and confirm it's working as well.
Jesus
HuynhVanThuan
Hi JeusE,
Regard,
Huynh
JesusE_Intel
Thank you for confirming. If you need any additional information, please submit a new question as this thread will no longer be monitored.
