Edge Software Catalog
Объявления
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Обсуждение
ESDQ 5.0 on ElKhart Lake Platform
Funway
Начинающий
12 192Просмотр.
Dear Sirs
We run ESDQ 5.0 on Elkhart lake platform and there are many failed items . Could you have some suggestions for failed  items ?
Best Regards
Funway
Метки (1)
0 баллов
1 Решение
Xiang_Intel
Модератор
11 200Просмотр.
Hi Funway,
Just a piece of follow-up information, you can enable the HEVC VDEnc on your platform by following the steps below.
Media sdk sample encode test failed with the message:
“ERROR], sts=MFX_ERR_UNSUPPORTED(-3),…"
Follow the steps below as a possible solution:
sudo apt install --reinstall linux-firmware
Add i915.enable_guc=2  in /etc/default/grub: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.force_probe=* i915.enable_guc=2"
sudo update-initramfs –u
sudo update-grub
Reboot the system.
After reboot, execute the command:  dmesg | grep guc
Verify the logs for guc information. If output doesn't contain guc details, then get the latest guc/huc firmware. Copy the firmware to /lib/firmware/i915/, and reboot the system.
This will help to enable the HEVC VDEnc on your platform and rerun the test again. The “mediasdk_sample_encode_with_h265” test case should be able to run successfully.
Do let me know if there is still issue after you run these changes and do help me to accept as solution if this help to fix the issue.
Xiang Yang
Просмотреть решение в исходном сообщении
23 Ответы
JesusE_Intel
Модератор
1 194Просмотр.
Hi Funway,
Looking at the latest test report all tests passed. I noticed you have Kernel 5.4.143-asrock-custom-mr2-v0.2 installed and in the test report from 2021-11-16 you had kernel 5.11.0-40-generic. Please confirm if changing the kernel and enabling HEVC VDEnc as Xiang Yang suggested resolved your issue.
Jesus
JesusE_Intel
Модератор
1 145Просмотр.
Hi Funway,
Please let me know if you have any additional questions or if we can proceed to close this discussion.
Jesus
JesusE_Intel
Модератор
1 143Просмотр.
Ответить
