Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
ESDQ 'eiv' module issue
LingIs
Hi, I downloaded intel ESDQ for Vision and then installed it. The result showed that it was successful, but there was a problem when running esdq run. The following are the attached files, thank you!
Vision module install log
Wan_Intel
Hi LingIs,
For your information, I've downloaded and installed Intel® Edge Software Device Qualification for Vision version 2.1 on Ubuntu 22.04 LTS.
I'm facing the same error when running Intel® ESDQ for Vision test. Let me check with relevant team and I'll update you at the earliest.
Meanwhile, could you please share the following information with us?
  • Version of Intel® Edge Software Device Qualification for Vision
  • Operating System
  • Processor
Wan
LingIs
Hi, Thanks for your reply!
The version of Intel® Edge Software Device Qualification for Vision : 2.1
Operating System : Ubuntu 22.04.4 LTS
Processor : Screenshot from 2024-04-29 10-21-12.png
The above is the information of my computer, thank you!
Wan_Intel
Hi LingIs,
Thanks for your patience.
Could you please provide the log file located in ~/esdq/logs after running esdq run inside ~/esdq?
Wan
LingIs
Attached is the log file, thank you!
Wan_Intel
Hi LingIs,
Thanks for sharing the log file with us.
We'll further investigate the issue and update you as soon as possible.
Wan
Wan_Intel
Hi LingIs,
We've received feedback from the relevant team. Our team has confirmed the issue and we will further investigate the issue.
Meanwhile, as a workaround, please unzip the ZIP file in this thread into the following directory: ~/esdq/modules/eiv/, and you can go ahead and run the esdq run command.
Wan
LingIs
Thanks for your reply.
I will test it out and provide feedback afterwards, thank you very much!
LingIs
After I tried it, another problem occurred. The following attachment is the log file, thank you!
Wan_Intel
Hi LingIs,
Thanks for the information.
Our development team also encountered issues with the latest Intel® ESDQ for Vision package, and we are working to address them in the next release. However, we don't have an ETA on it.
Sorry for the inconvenience and thank you for your support.
Sincerely,
Wan
Wan_Intel
Hi LingIs,
We've received an update from relevant team. Intel® Edge Software Device Qualification (Intel® ESDQ) for Vision has been removed from Edge Software Hub. Could you please try the latest Intel® ESDQ packages and see if the issue can be resolved?
Wan
Wan_Intel
Hi LingIs,
Thanks for your question.
This thread will no longer be monitored since we have provided a workaround. If you need additional information from Intel, please submit a new question.
Wan
