Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
ESDQ for AMR Errors - System Requirements
huang__shiuan-chi
We have run the ESDQ test on our device.
We got failed in the test module AMR0.
The log file and the documents said this must be run on a 5.10.65 kernel version. but our system is in 5.13.0.
Is it a MUST that I need to fall back my kernel to an older version? Or if there's some trick to do with a newer kernel.
JesusE_Intel
Hi huang__shiuan-chi,
Thanks for reaching out. As you mentioned, Kernel 5.10.65 is one of the system requirements and test AMR 1 is checking that the system requirements are met. I also see a failed test when using Kernel 5.13, running the test with kernel 5.10.65 passes.
I will check with the team if there are any alternatives. In the meantime, are there any limitations that doesn't allow you to downgrade to the required kernel version?
Jesus
JesusE_Intel
Apologies for the delay, I've confirmed with my peers that Kernel 5.10.65 is the only supported version for this package. Please let me know if you have any additional questions.
Jesus
huang__shiuan-chi
JesusE_Intel
