Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
ESDQ for Mertro AI Test failed in OpenVINO Benchmark and GPU Freq Performance Test
jackys
Hello !
I encountered some issues in ESDQ for Metro AI Test.
The test case "OpenVINO Benchmark Test","GPU Freq Performance Test" have failed.
Attached,please check the ESDQ test report generated. Would you please share your comments and suggestions about this issue.
Thank you so much !
Jackys
JesusE_Intel
Hi Jackys,
That's correct, the system requirements list Intel Atom® X7000 Series and N-series processors. However, the tests should still run, and based on the output you provided, they don't appear to be running at all. I suggest trying the latest package to see if the results are the same. Please note that this still doesn't guarantee the tests will pass, as your system doesn't meet the requirements.
On my end, the tests completed and passed using a fresh Ubuntu 24.04 OS with Intel® Edge System Qualification (Intel® ESQ) for Metro AI Suite v2.0.0.
Jesus
JesusE_Intel
Hi Jackys,
It appears that the OpenVINO tests did not run. Could you try the troubleshooting steps mentioned in item #5 of the troubleshooting section in the documentation and let me know if that resolves the issue?
https://docs.openedgeplatform.intel.com/vision-automation-test-u20/user-guide/Get-Started-Guide.html#troubleshooting
Jesus
jackys
Hi Jesus,
I have retried running the OpenVINO tests,but it still failed.
Attached is command log,please review and share your comments and suggestions.
Thank a lot !
Jackys
jackys
Hi Jesus,
My problem hasn't been resolved,I have already replied to you, but haven’t received information.
Waiting for you news,Thank a lot !
Best Regards
Jackys
JesusE_Intel
Hi Jackys,
I apologize for the delay in my response. I was setting up a fresh environment to reproduce your issue and am currently running the full test suite. I will update you as soon as it's complete.
I noticed you may be using an older version of the software package (Metro_AI_Suite_Device_Qualification_for_Hardware_Builder_1.0). While I run my tests, could you try using the latest software package (v2.0)?
Jesus
jackys
Hi Jesus,
Thank for your kindly reply.
An overview like that of the Metro AI Suite Device Qualification Tool,the Atom x6000 series does not support testing?
https://edgesoftwarecatalog.intel.com/details/?microserviceType=recipe&microserviceNameForUrl=metro-ai-suite-device-qualification-for-hardware-builder
Please help me confirm the testing requirements,Thank a lot !
Best Regards
Jackys
JesusE_Intel
Hi Jackys,
Jesus
jackys
Hi Jesus,
I have already tried ESQ Test with Metro test module ver.2.0,the "GPU Freq Performance Test" still fail.
Perhaps the Atom x6000 series doesn't meet the requirements.
Thank you for your great support.
Best Regards
Jackys
JesusE_Intel
No problem! If you have any additional questions, please feel free to start a new discussion as this thread will no longer be monitored.
ethancarter199825
Thanks a lot! That worked perfectly. Everything’s running fine now.
