Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Edge AI Box (ESDQ) installation issue with modules/Aibox Test Module & Proxy Pipeline Module
ito_xactai
Hi Team,
While trying to install the ESDQ (Intel_Edge_AI_Box_4.0).We are getting an errors at the "modules/Aibox Test Module & Proxy Pipeline Module". Could anyone please help us to resolve this issue.
System Configuration:
Model: Intel NUC 12 Enthusiast Kit
Processor: 12th Generation Intel-i7-12700H Processor
GPU: Intel iris xe Graphics , Intel Arc A770M Graphics
OS: Ubuntu-22.04
Disk: 512GB
RAM: 32 GB
Below are the error details:
modules/Aibox Test Module & Proxy Pipeline Module Errors:
mbind failed: Operation not permitted
The following packages have unmet dependencies:
libze-intel-gpu1 : Breaks: intel-level-zero-gpu
E: Unable to correct problems, you have held broken packages.
The command '/bin/bash -o pipefail -c set -e -o pipefail; if [ "$IS_XEON_PLATFORM" = "true" ] ; then apt update && apt install sudo numactl -y; echo "aibox ALL=(ALL) NOPASSWD: /usr/bin/ln" | tee /etc/sudoers.d/user-conf && chmod 0440 /etc/sudoers.d/user-conf ; else apt update -y && apt install -y sudo intel-gpu-tools xpu-smi ; set -e -o pipefail && echo "aibox ALL=(ALL) NOPASSWD: /usr/bin/intel_gpu_top,/usr/bin/rm,/usr/bin/xpu-smi" | tee /etc/sudoers.d/user-conf && chmod 0440 /etc/sudoers.d/user-conf ; fi' returned a non-zero code: 100
Failed to install Intel Edge AI Box Qualifcation Suit
Failed to install modules/Aibox_Test_Module took 23 minutes 0.47 seconds
Thanks & Regards,
ITO - XactAI.
Iffa_Intel
Thank you, I look forward to your update.
Cordially,
Iffa
ito_xactai
Hi @Iffa_Intel  and @SShan_Intel
I followed instructions mentioned in the below link and able to run the ESDQ successfully but only the change i made in this file ~/intel_edge_aibox/edgesoftware_configuration.xml . Uncomment every line and run the "./edgesoftware install
Solution link:
community.intel.com/t5/Edge-Software-Catalog/Edge-AI-Box-ESDQ-installation-issue-with-modules-Aibox-Test/m-p/1648105#M901
Thanks for your support
Thanks & Regards,
ITO - XactAI.
Iffa_Intel
Thanks for the update. Glad that you've solved the issue.
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
