Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Error when installing EII Software
DarkHorse
Hi Experts,
Want to check if anyone of you guys see this error messages before during installation process of EII software in Ubuntu 18.04
DarkHorse
Hello @Murni_J_Intel ,
Thanks for the recommendation.
After I refresh my PC with new Ubuntu 18.04 and reinstall EII software, the issue has been resolved.
Murni_J_Intel
May I check with you which package are you using for this installation?
if you are running the installation behind a corporate proxy, please help configure the http and https proxy at /etc/environment file and try to re-run the script.
It will be best if you can use a fresh and clean system for the installation, or you can remove the previous docker CE and docker compose if there is any existing that being installed in your system.
DarkHorse
