Edge Software Catalog
488 Discussions
Failed to install bmra_base
ito_xactai
Hi All
While trying to install the ESDQ.We are getting an error at the "bmra_base" step
W:GPG error: https://repositories.intel.com/gpu/ubuntu jammy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 28DA432DAAC8BAEA, E:The repository 'https://repositories.intel.com/gpu/ubuntu jammy InRelease' is not signed
it might be the issue with GPG key and it no longer available.Anyone please help us to solve this issue and please check the attached screenshots for more details
Iffa_Intel
could you share:
  1. Which guide are you referring to and what version? (latest is version 11.0.0 )
  2. Did you use any proxy?
  3. Any chance that you tried to re-download that using different network connection?
Cordially,
Iffa
ito_xactai
@Iffa_Intel  thanks for the quick response
I'm using this guide "https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-aibox.html"
when i check this version 11.0.0 and tried to download the Intel® ESDQ for AI Box for Video Analytics      it redirects to another page so i was download from there
No
Yes I was tried and re-download multiple times with different network connection
Could you please provide the documentation link and download link of ESDQ 11.0.0
ito_xactai
@Iffa_Intel
Still facing the same issue.I think the repository is expired or something because when i was check the below URL it show "release streams" in particularly the production section it says intel gives a support up-to 6 months.Why i assume like this because in "May" month i was successfully installed the ESDQ.Right-now i'm not able to install the ESDQ on the same machine and i tried to install multiple machines with multiple Internet connectivity also.Please help me to solve this issue
URL:  https://dgpu-docs.intel.com/driver/release-streams.html#ubuntu-server-22-04
Iffa_Intel
We'll further investigate this and get back to you asap.
Cordially,
Iffa
ito_xactai
Hi @Iffa_Intel
Could you please give an update on this issue
Thanks & Regards,
ito_xactai
Iffa_Intel
ESDQ for AI Box version 4.0 has been released and looks like the issue has been fixed.
Could you please help to try on the latest version?
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
