Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
How to config Smart NVR Proxy Pipeline .
topgun97
Hello everyone,I installed Intel® Edge AI Box(v4.0).I run Smart NVR Proxy Pipeline with custom_models(yolov5s-416+license-plate-recognition-barrier-0007). $ ./run_container.sh smart_nvr.cfg [][][run_smart_nvr_runner][line:69]------------------------------------------------------------------------------------------------------------------------ [][][run_smart_nvr_runner][line:69]Running Smart NVR Proxy Pipeline with config: [model: yolov5s-416+license-plate-recognition-barrier-0007, device: iGPU, AI stream: 3]. [][][run_smart_nvr_runner][line:69]------------------------------------------------------------------------------------------------------------------------ [][][run_smart_nvr_runner][line:87]------------------------------------------------------------------------------------------------------------------------ [][][run_smart_nvr_runner][line:87]Smart NVR pipeline execution with config [model: yolov5s-416+license-plate-recognition-barrier-0007, device: iGPU, AI stream: 3] is finished [][][run_smart_nvr_runner][line:87]------------------------------------------------------------------------------------------------------------------------ [][][run_smart_nvr_runner][line:88]------------------------------------------------------------------------------------------------------------------------ [][][run_smart_nvr_runner][line:88]Check result in /home/topgun/intel_edge_aibox/Intel_Edge_AI_Box_4.0/Proxy_Pipeline_Module/output/smart_nvr_proxy_pipeline_with_config.csv [][][run_smart_nvr_runner][line:88]------------------------------------------------------------------------------------------------------------------------ The resule : Pipeline_Test,Device Used,Input Codec,Input Resolution,Input Channels,Model,Compose,Number of Monitors,AI Channels,AVG FPS,AVG CPU Freq(MHz),AVG CPU Util(%),AVG Memory Util(%),AVG GPU Freq(MHz),AVG GPU EU(RCS) Util(%),AVG GPU VDBox(VCS) Util(%),AVG package power(W),AVG GPU power(W),Duration(s),Result Smart_NVR_Proxy_Pipeline,iGPU,H264 (4Mbps),1080p@20,25,vehicle-license-plate-detection-barrier-0123+license-plate-recognition-barrier-0007,5x5,1,3,0,1374.97,80.00,0.90,62.00,0.11,0.00,10.98,0.27,2,No Error Smart_NVR_Proxy_Pipeline,iGPU,H264 (4Mbps),1080p@20,25,yolov5s-416+license-plate-recognition-barrier-0007,5x5,1,3,0,3092.30,177.14,3.87,111.50,0.81,0.60,54.74,0.41,15,No Error My question is how to config Smart NVR Proxy Pipeline to Inference the RTSP video stream. Thank you!
Aznie_Intel
Hi Topgun97,
Thanks for reaching out. You can specify multiple camera sources by -i rtsp://camera1_url,rtsp://camera2_url,....
You can take a look at this documentation.
Hope this helps.
Aznie
Aznie_Intel
Hi Topgun97,
Hope this helps.
Aznie
Aznie_Intel
Hi Topgun97,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
