Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Install Metro_AI_Suite_Device_Qualification Fail
JanHung
Hi Intel,
I tried running the installation packages for Metro_AI_Suite_Device_Qualification 1.5.1 and 1.5, but both installations failed. The va enable node module cannot be installed.
System
OS: Ubuntu 24.04.2 LTS
Processor: Intel Core Ultra 7 256U x 14
Memory:64G
The error message is as follows:
Version 1.5:
Run ./edgesoftware update <Failed Module ID(s)> still fail
Version 1.5.1:
JesusE_Intel
Hi JanHung,
We've added a workaround for this issue in the troubleshooting section of the documentation. Could you please give it a try and let me know if it resolves the issue for you?
https://docs.openedgeplatform.intel.com/vision-automation-test-u20/user-guide/Get-Started-Guide.html#troubleshooting
Jesus
JesusE_Intel
Hi JanHung,
Thank you for reporting the issue. I have successfully reproduced it and am currently consulting with the engineering team to find a fix or workaround. I will update you as soon as I have more information.
Jesus
JesusE_Intel
Hi JanHung
The engineering team is working on a fix, which should be available in the next release.
Currently, there are two issues. For the Media Communications Mesh (MCM) issue you encountered, please try the following workaround:
1. Navigate to the installation directory
cd <working dir>/Metro_AI_Suite_Device_Qualification
2. Edit install_pkgs_status file
vi install_pkgs_status
3. Update the mcm_build_status by changing the value from 0 to 1:
mcm_build_status=1
4. Re-run the installation command
./edgesoftware install
The second issue you might encounter is related to the XPUM version. I'm currently waiting to see if there's another workaround available while we anticipate the next software release.
Jesus
JanHung
Thank you, JesusE.
However, even after modifying install_pkgs_status, I'm still unable to install the va enable node.
The error is as follows:
JesusE_Intel
Hi JanHung,
Jesus
AmandaLee
Hi Jesus,
I followed the troubleshooting steps and applied the patch, but it's still failing.
Amanda
JanHung
Hi Jesus,
I went through the recommended troubleshooting steps and performed a reboot. That resolved the issue successfully. Thank you very much.
JesusE_Intel
Hi JanHung, thanks for confirming that the troubleshooting steps worked for you.
Hi Amanda, could you try the steps on a fresh OS or a different system? Your screenshot indicates there might be an issue with some package dependencies.
AmandaLee
Hi Jesus,
Thanks for your reply.
On this same system, I've only installed "esq for ai edge system." Can these two packages coexist?
JesusE_Intel
Hi AmandaLee,
It's not recommended, as some components may interfere with each other. Could you please try on a fresh OS installation and let me know if the same issue occurs?
Jesus
AmandaLee
Hi Jesus,
I've reinstalled it on a fresh OS, and it works successfully. Thank you.
Amanda
JesusE_Intel
The reported issue on this thread has been resolved, if additional assistance is needed, please create a new discussion as this thread will no longer be monitored.
