Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
Intelligent Traffic Management Grafana container not running
YY4
when following the steps at:
https://software.intel.com/content/www/us/en/develop/articles/intelligent-traffic-management.html
to run the demo, i can see that grafana actually not running with a error message when checking the log:
itm_smartcity | 2021-08-15 :: Connecting grafana: Grafana container not up yet, retrying...
seems the grafana container never started, i try to restart it manually buy failed...
attached the log
Murni_J_Intel
Hi @YY4
Can you please share your $ docker ps and $ docker logs -f itm_smarticty output?
please ensure to run the below to set the host IP before you run the $ docker-compose up -d command
export HOST_IP=$(hostname -I | cut -d' ' -f1)
YY4
please see attached log, thanks so much!
YY4
refreshed the whole SW but still not be able to bring up.
Xiang_Intel
Hi @YY4 ,
I am able to reproduce your issue stated above. It is found that when the HOST_IP env variable is set not correctly, then will see this issue.
Based on the log you have provided, the host ip is set to 172.17.0.1.
Can I request your help to verify again?
Steps:
1. In a new terminal, go to Intelligent_Traffic_Management_<version>/Intelligent_Traffic_Management/intelligent-traffic-management
2. export your current machine IP address. (You can look up your system IP address via ip a or ifconfig).
    export HOST_IP=<System-IP-address>
3. Verify that HOST_IP is correctly sourced into the environment.
     export | grep HOST_IP
4. Then run docker-compose up.
     sudo -E docker-compose up
YY4
sorry not updated the latest status in time, i have fixed the issue, really appreciate for the supports.
Xiang_Intel
Great to hear this from you.
JesusE_Intel
