Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
QSPI booting
Ramakrishnan
=> setenv bootcmd sf probe;sf read 2000000 2000000 300000;fpga load 0 2000000 300000;sf read 1000000 100000 100000;go 1000040
While running the above command in the u-boot, im getting an error which says command 'load' failed.
device 0 offset 0x2000000, size 0x300000
SF: 3145728 bytes @ 0x2000000 Read: OK
Command 'load' failed: Error -6
device 0 offset 0x100000, size 0x100000
SF: 1048576 bytes @ 0x100000 Read: OK
## Starting application at 0x01000040 ...
undefined instruction
pc : [<01000040>] lr : [<0ff691d5>]
reloc pc : [<f209e080>] lr : [<01007215>]
sp : 0fb4cea8 ip : 00000000 fp : 00000002
r10: 0fb74c98 r9 : 0fb51ec0 r8 : 0ffe44d0
r7 : 0ff7ac85 r6 : 00000002 r5 : 01000040 r4 : 0fb74c9c
r3 : 01000040 r2 : 0fb74c9c r1 : 0fb74c9c r0 : 00000001
Flags: nzCv IRQs off FIQs off Mode SVC_32
Code: ffffffff ffffffff ffffffff ffffffff (ffffffff)
Resetting CPU ...
JesusE_Intel
Hi Ramakrishnan,
Which software package from Edge Software Hub are you using? Could you please share additional steps and configuration details to reproduce from my end?
Jesus
JesusE_Intel
Hi Ramakrishnan,
Jesus
JesusE_Intel
