Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
Service 'tls_core' failed to build
huang06
EIS version: Edge_Insights_for_Industrial_2.3.2
OS version: Ubuntu 18.04.5 LTS
I try to install Intel_Training_and_Learning_Suite_TLS, I follow and execute commands in README.md.
But I got error messages during the docker installation after executing the following command:
./setup_TLS_docker.sh
ChoonHwa
Hi Huang06,
New finding. To solve this issue, can you please open the requirements.txt file located at <TLS2.0 project source code>/nnframework/tf/ in text editor,  add the  h5py==2.10.0 into last row. Then re-run the ./setup_TLS_docker.sh
ChoonHwa
Hi Huang06,
The installation will take times to download and install through network, and sometimes instable network may cause some download failed. May I know do you try to re-run the ./setup_TLS_docker.sh again without doing any changes? Can you please invoke the ./setup_TLS_docker.sh and observe if the issue is resolve?
ChoonHwa
Hi Huang06,
