Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Smart Video and AI Workload installation failed
yahanda
I was trying to install "Smart Video and AI Workload" by following instruction, but receiving "Module validation failed" error every time I try to install it on system.
Smart Video and AI Workload (intel.com)
Logs
$ ./edgesoftware install
Please enter the Product Key. The Product Key is contained in the email you received from Intel confirming your download:  ****************
Starting the setup...
ESB CLI version: 2022.2
Target OS: Ubuntu 20.04
Python version: 3.8.10
Checking Internet connection
Connected to the Internet
Validating package product key
Successfully validated Product Key
Checking for prerequisites
All dependencies met
-------------------SYSTEM INFO--------------------
Package Name: Smart Video and AI workload Reference Implementation 2021.4
Product Name: Microsoft Corporation Virtual Machine
CPU SKU: Intel(R) Xeon(R) Platinum 8272CL CPU @ 2.60GHz
Memory Size: 16 GB
Operating System: Ubuntu 20.04.4 LTS
Kernel Version: 5.15.0-1014-azure
Accelerator: None
CPU Utilization: 2.7%
Available Disk Space: 482 GB
Starting installation
Downloading modules...
Downloading component esb_common
100%|ヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲ| 43.6M/43.6M [00:08<00:00, 5.43MiB/s]
Module validation passed for 6022bd8ccc7449002afdbedd
Successfully downloaded module esb_common
Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime
100%|ヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲ| 7.72M/7.72M [00:00<00:00, 85.0MiB/s]
Module validation failed for 60e07fd84c1e9d002a6d6a17. 409 Conflict
Validation failed, deleting module 60e07fd84c1e9d002a6d6a17
Retrying module download
100%|ヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲ| 7.72M/7.72M [00:00<00:00, 61.6MiB/s]
100%|ヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲ| 7.72M/7.72M [00:00<00:00, 81.2MiB/s]
Failed to connect. Please check the Internet connection and proxy settings. Exiting download.
Downloading component Smart_Video_and_AI_workload_Reference_Implementation
100%|ヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲヲ| 1.17M/1.17M [00:00<00:00, 2.35MiB/s]
Module validation passed for 6156edcd0513ff0020ee0bb0
Successfully downloaded module Smart_Video_and_AI_workload_Reference_Implementation
Downloading modules completed...
Installing shared module 'esb_common'
Unzipping the shared module 'esb_common'...
running install
running bdist_egg
running egg_info
creating esb_common.egg-info
writing esb_common.egg-info/PKG-INFO
writing dependency_links to esb_common.egg-info/dependency_links.txt
writing top-level names to esb_common.egg-info/top_level.txt
writing manifest file 'esb_common.egg-info/SOURCES.txt'
reading manifest file 'esb_common.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-x86_64/egg
running install_lib
warning: install_lib: 'build/lib' does not exist -- no Python modules to install
creating build
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/egg
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying esb_common.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/esb_common-0.1-py3.8.egg' and adding 'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing esb_common-0.1-py3.8.egg
Removing /usr/local/lib/python3.8/dist-packages/esb_common-0.1-py3.8.egg
Copying esb_common-0.1-py3.8.egg to /usr/local/lib/python3.8/dist-packages
esb-common 0.1 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.8/dist-packages/esb_common-0.1-py3.8.egg
Processing dependencies for esb-common==0.1
Finished processing dependencies for esb-common==0.1
Successfully installed shared module 'esb_common'.
Unzipping the module Smart_Video_and_AI_workload_Reference_Implementation...
Modules to be installed by package are ['Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime', 'Smart_Video_and_AI_workload_Reference_Implementation']
Failed to install Intel_Distribution_of_OpenVINO_toolkit_2021_4_Runtime due to missing file
Installing Smart_Video_and_AI_workload_Reference_Implementation
('python version:', 3)
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'python-is-python2' instead of 'python'
python-is-python2 is already the newest version (2.7.17-4).
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
libxext-dev is already the newest version (2:1.3.4-0ubuntu1).
libxfixes-dev is already the newest version (1:5.0.3-2).
libdrm-dev is already the newest version (2.4.107-8ubuntu1~20.04.2).
Checking GPU generation number.                    [.........................                         ]  50%
Failed to install Smart_Video_and_AI_workload_Reference_Implementation. cat: /sys/kernel/debug/dri/0/i915_capabilities: No such file or directory
Installation of package complete
|            Id            |                         Module                        | Status |
| 60e07fd84c1e9d002a6d6a17 | Intel Distribution of OpenVINO toolkit 2021 4 Runtime | FAILED |
| 6156edcd0513ff0020ee0bb0 |  Smart Video and AI workload Reference Implementation | FAILED |
JesusE_Intel
Hi Yasuhiro,
We have updated the reference implementation package. Could you please redownload and try again? Please let me know if you run into any issues.
Jesus
JesusE_Intel
Hi yahanda,
Apologies for the delay in our response, I moved your post to the Edge Software Hub forum as it was originally posted on the OpenVINO forum.
Could you tell me more about your system? Does it meet the Target System Requirements? From the installation error, it seems it cannot find a Graphics driver.
Jesus
yahanda
Hello Jesus,
Thank you for the response. It may be because I was trying to install it on Azure VM. Will try on a physical machine.
Yasuhiro
yahanda
Hi Jesus,
By installing on a physical machine, the graphics driver error disappeared and "Smart Video and AI workload Reference Implementation" was installed successfully, but OpenVINO installation was still failed. Did I miss something? Any advice is greatly appreciated.
ubuntu@ubuntu-n131wu:~/Downloads/smart_video_ai_workload$ ./edgesoftware install
Product Name: MouseComputer Co.,Ltd. N131WU
CPU SKU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
Memory Size: 8 GB
Kernel Version: 5.15.0-41-generic
Accelerator: None
CPU Utilization: 1.6%
Available Disk Space: 208 GB
WARNING: Installation may fail. The target device does not meet the minimum system requirement.
Minimum memory requirement for this package: 16 GB.
Minimum disk requirement for this package: 256 GB.
100%|██████████████████████████████████| 43.6M/43.6M [00:02<00:00, 16.9MiB/s]
100%|██████████████████████████████████| 7.72M/7.72M [00:01<00:00, 7.67MiB/s]
100%|██████████████████████████████████| 7.72M/7.72M [00:00<00:00, 14.3MiB/s]
100%|██████████████████████████████████| 7.72M/7.72M [00:00<00:00, 15.6MiB/s]
100%|██████████████████████████████████| 1.17M/1.17M [00:00<00:00, 2.01MiB/s]
running install
running bdist_egg
running egg_info
running install_lib
creating build
creating dist
The following package was automatically installed and is no longer required:
  libfwupdplugin1
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib python2
  python2-minimal python2.7 python2.7-minimal
Suggested packages:
  python2-doc python-tk python2.7-doc binfmt-support
The following NEW packages will be installed:
  python-is-python2 python2 python2-minimal python2.7 python2.7-minimal
0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,815 kB of archives.
After this operation, 16.5 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 libpython2.7-minimal amd64 2.7.18-1~20.04.3 [336 kB]
Get:2 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 python2.7-minimal amd64 2.7.18-1~20.04.3 [1,280 kB]
Get:3 http://archive.ubuntu.com/ubuntu focal/universe amd64 python2-minimal amd64 2.7.17-2ubuntu4 [27.5 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 libpython2.7-stdlib amd64 2.7.18-1~20.04.3 [1,888 kB]
Get:5 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 python2.7 amd64 2.7.18-1~20.04.3 [248 kB]
Get:6 http://archive.ubuntu.com/ubuntu focal/universe amd64 libpython2-stdlib amd64 2.7.17-2ubuntu4 [7,072 B]
Get:7 http://archive.ubuntu.com/ubuntu focal/universe amd64 python2 amd64 2.7.17-2ubuntu4 [26.5 kB]
Get:8 http://archive.ubuntu.com/ubuntu focal/universe amd64 python-is-python2 all 2.7.17-4 [2,496 B]
Fetched 3,815 kB in 2s (1,668 kB/s)
Selecting previously unselected package libpython2.7-minimal:amd64.
(Reading database ... 304928 files and directories currently installed.)
Preparing to unpack .../0-libpython2.7-minimal_2.7.18-1~20.04.3_amd64.deb ...
Unpacking libpython2.7-minimal:amd64 (2.7.18-1~20.04.3) ...
Selecting previously unselected package python2.7-minimal.
Preparing to unpack .../1-python2.7-minimal_2.7.18-1~20.04.3_amd64.deb ...
Unpacking python2.7-minimal (2.7.18-1~20.04.3) ...
Selecting previously unselected package python2-minimal.
Preparing to unpack .../2-python2-minimal_2.7.17-2ubuntu4_amd64.deb ...
Unpacking python2-minimal (2.7.17-2ubuntu4) ...
Selecting previously unselected package libpython2.7-stdlib:amd64.
Preparing to unpack .../3-libpython2.7-stdlib_2.7.18-1~20.04.3_amd64.deb ...
Unpacking libpython2.7-stdlib:amd64 (2.7.18-1~20.04.3) ...
Selecting previously unselected package python2.7.
Preparing to unpack .../4-python2.7_2.7.18-1~20.04.3_amd64.deb ...
Unpacking python2.7 (2.7.18-1~20.04.3) ...
Selecting previously unselected package libpython2-stdlib:amd64.
Preparing to unpack .../5-libpython2-stdlib_2.7.17-2ubuntu4_amd64.deb ...
Unpacking libpython2-stdlib:amd64 (2.7.17-2ubuntu4) ...
Setting up libpython2.7-minimal:amd64 (2.7.18-1~20.04.3) ...
Setting up python2.7-minimal (2.7.18-1~20.04.3) ...
Linking and byte-compiling packages for runtime python2.7...
Setting up python2-minimal (2.7.17-2ubuntu4) ...
(Reading database ... 305675 files and directories currently installed.)
Preparing to unpack .../python2_2.7.17-2ubuntu4_amd64.deb ...
Unpacking python2 (2.7.17-2ubuntu4) ...
Selecting previously unselected package python-is-python2.
Preparing to unpack .../python-is-python2_2.7.17-4_all.deb ...
Unpacking python-is-python2 (2.7.17-4) ...
Setting up libpython2.7-stdlib:amd64 (2.7.18-1~20.04.3) ...
Setting up python2.7 (2.7.18-1~20.04.3) ...
Setting up libpython2-stdlib:amd64 (2.7.17-2ubuntu4) ...
Setting up python2 (2.7.17-2ubuntu4) ...
Setting up python-is-python2 (2.7.17-4) ...
Processing triggers for mime-support (3.64ubuntu1) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
libxext-dev set to manually installed.
libxfixes-dev set to manually installed.
  libfwupdplugin1
  libpciaccess-dev
  libdrm-dev libpciaccess-dev
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 151 kB of archives.
After this operation, 780 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu focal/main amd64 libpciaccess-dev amd64 0.16-0ubuntu1 [20.3 kB]
Get:2 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 libdrm-dev amd64 2.4.107-8ubuntu1~20.04.2 [131 kB]
Fetched 151 kB in 1s (106 kB/s)
Selecting previously unselected package libpciaccess-dev:amd64.
(Reading database ... 305707 files and directories currently installed.)
Preparing to unpack .../libpciaccess-dev_0.16-0ubuntu1_amd64.deb ...
Unpacking libpciaccess-dev:amd64 (0.16-0ubuntu1) ...
Selecting previously unselected package libdrm-dev:amd64.
Preparing to unpack .../libdrm-dev_2.4.107-8ubuntu1~20.04.2_amd64.deb ...
Unpacking libdrm-dev:amd64 (2.4.107-8ubuntu1~20.04.2) ...
Setting up libpciaccess-dev:amd64 (0.16-0ubuntu1) ...
Setting up libdrm-dev:amd64 (2.4.107-8ubuntu1~20.04.2) ...
Checking Openvino Installation Status.             [..................................................] 100%
Checking OpenCL NEO Drivers.                       [..................................................] 100%
Downloading Smart Video and AI Workload Repository [..................................................] 100%
Downloading Sample Videos.                         [..................................................] 100%
Installation started. This might take up to 30 minutes
Installing: Smart Video and AI Workload RI.        [..................................................] 100%
Verifying Smart Video and AI Workload Installation. [..................................................] 100%
Please refer the User guide 'concurrent_video_analytic_sample_application_user_guide.pdf' at this link https://github.com/intel-iot-devkit/concurrent-video-analytic-pipeline-optimization-sample-l/blob/master/doc/concurrent_video_analytic_sample_application_user_guide.pdf
Successfully installed Smart_Video_and_AI_workload_Reference_Implementation took 13 minutes 57.53 seconds
| 6156edcd0513ff0020ee0bb0 |  Smart Video and AI workload Reference Implementation | SUCCESS |
Yasuhiro
JesusE_Intel
Hi Yasuhiro,
I don't believe this Reference Implementation has been validated on Azure VM. Please let me know if you run into any issues on a physical machine.
Jesus
yahanda
Hi Jesus,
Memory Size: 8 GB
Accelerator: None
running install
running bdist_egg
running egg_info
running install_lib
creating build
creating dist
  libfwupdplugin1
Suggested packages:
  libfwupdplugin1
  libpciaccess-dev
Yasuhiro
yahanda
Hi Jesus,
Memory Size: 8 GB
Accelerator: None
running install
running bdist_egg
running egg_info
running install_lib
creating build
creating dist
  libfwupdplugin1
Suggested packages:
  libfwupdplugin1
  libpciaccess-dev
Yasuhiro
yahanda
Hi Jesus,
Memory Size: 8 GB
Accelerator: None
running install
running bdist_egg
running egg_info
running install_lib
creating build
creating dist
  libfwupdplugin1
Suggested packages:
  libfwupdplugin1
  libpciaccess-dev
yahanda
Hi Jesus,
Yasuhiro
JesusE_Intel
Hi Yasuhiro,
I am also seeing an installation failure with OpenVINO when installing Smart Video and AI Workload RI. Let me escalate to the development team for further investigation.
Jesus
JesusE_Intel
Hi Yasuhiro,
Jesus
JesusE_Intel
