Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Software Module Repository
Rajnish
while installing smr in server node i an getting following errors.I have tried renaming it but still facing the issue.
looking for help.
{INFO}: Restarting Docker Daemon
{INFO}: Starting CSL Software Module Repository
docker: Error response from daemon: Conflict. The container name "/docker_auth" is already in use by container "2e450154767742efe19fa0201acaf6f36e22f0f36282b674d4a161198773944a". You have to remove (or rename) that container to be able to reuse that name.
See 'docker run --help'.
{ERR}: Cannot start Docker Auth Service
{ERR}: Something went wrong when trying to install SMR
{ERR}: CSL Software Module Repository bootstrap failed
{INFO}: Start Cleanup
{INFO}: End Cleanup
Rajnish
Issue is resolved now.kindly ignore it.
Thank you...!!
